Author Topic: Brake and parking brake question  (Read 19273 times)
« on: December 15, 2009, 07:42:35 pm »
OK so today I replaced all the cables on my 79 K10 SB. Well, put them in. The previous owner hacked them all out for some reason, I think because of the exhaust. It touches the brake cables when taught. The only thing I couldnt figure out, even with looking through my parts catalog where I got the stuff from, is how the equalizer cable attaches to the passenger side under the door. I took a picture of it. The bracket shown is C shaped, riveted to the frame with that hole in it. Im wondering what is missing. The catalog doesnt have a part listed for my truck. Thanks
« Last Edit: December 15, 2009, 08:22:53 pm by beastie_3 »
Re: Parking brake question
« Reply #1 on: December 15, 2009, 08:22:12 pm »
I also replaced my rear brakes today. I couldnt figure out where these metal clips went, as there werent any to begin with and my factory manual didnt show them either. Any ideas?
Offline fitz
Re: Brake and parking brake question
« Reply #2 on: December 15, 2009, 08:42:36 pm »
  There is a metal rod that fits into that bracket in the pic and then it extends out a few inches to hold the cable. Tough to explain without a picture but you are missing a piece. Hopefully someone can post a pic for you.
  I converted my 81 to the newer style cables that both run up the drivers side.
Offline fitz
« Reply #3 on: December 15, 2009, 08:46:59 pm »
 Those metal clips get pressed into the holes in back of the backing plates that you use to andjust the starwheel adjuster.
« Reply #4 on: December 15, 2009, 09:02:13 pm »
this might help
« Reply #5 on: December 15, 2009, 09:24:31 pm »
Irish, that is the catalog I have. For a 2wd, it says to use #9. #8 is for 81+. Will it still work even though its not listed for 4wd??
Can anyone post a pic of that piece on their 73-80?
« Reply #6 on: December 15, 2009, 09:26:50 pm »
OK, cool. I dont have holes for my starwheel adjusters on the backing plate. The holes are on the drums. Ill see if they fit on them.
« Reply #7 on: December 17, 2009, 10:02:01 am »
it will be the same 4x4 and 4x2 frames are pretty much the same thing
« Reply #8 on: December 17, 2009, 01:04:07 pm »
OK Ill add it to my list of parts to order.
Offline Donut
« Reply #9 on: December 18, 2009, 06:41:57 am »
I'm pretty sure they get mounted on the shoe, not the backing plate.
As far as your brake cable "hooks".  I've got one on the passenger side (no. 9 in the illustration)  Mounting end, I have hooked into a hole in the transfer case mount on the frame rail.
The  pic doesn't show it real well, but the rust colored rod is for my e-brake.
« Last Edit: December 18, 2009, 06:48:23 am by Donut »
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
« Reply #10 on: December 21, 2009, 03:29:44 pm »
When it stops raining, Ill see what I can figure out. I may take a trip to the junk yard and see how others are set up as well.
Offline fitz
« Reply #11 on: December 21, 2009, 04:42:08 pm »
I can get some pics when the snow clears, Just noticed one of my parts trucks has this set up on it. I know it didn't hook to the t-case mount from the factory.
« Reply #12 on: December 22, 2009, 08:24:55 pm »
Fitz, that would be awesome if you had some pics. Take your time, Im not in a hurry.
Is that the only hook you have on the passenger side? Im just asking because the catalog shows two on the passenger side under the floorboard. Wouldnt happen to have a better pic, would you?
Offline SLOW-N-LOW74
« Reply #13 on: December 22, 2009, 08:26:17 pm »
If irish is right it hooks up to the upper part of the frame under the door, thats where i had mine when i was doing my tranny crossmember. Check out the pic i just took, this is as close as i can get without breaking out the jack hope this helps (sorry, the pic is sideways and blurry)
Hey beastie what color is your interior
« Last Edit: December 22, 2009, 08:47:09 pm by SLOW-N-LOW74 »
1974 CHEVY C-10 SHORT BED
1971 CHEVY SS CHEVELLE
1992 NISAN SENTRA (WITH A CHERRY BOMB)
DOUG
Offline Donut
« Reply #14 on: December 22, 2009, 08:59:03 pm »
beastie- mine is a very incomplete setup.  The only hook I have is the one I have on the transfercase mount.  Even the 2 guides in the illustration are missing on mine, but the cables are good and it works.  (actually it was on my list of things to do this past summer  :-\)
350/tbh350/np205
