Author Topic: switching cabs from 79 2wd to 78 4wd  (Read 4110 times)
Offline ucstepside
« on: January 21, 2010, 11:14:51 am »
newbie here....Can i switch a 79 2wb cab to a 78 4wd frame without problems beside cutting the hole for the 4wd shifter...
thanks
Re: switching cabs from 79 2wd to 78 4wd
« Reply #1 on: January 21, 2010, 03:49:25 pm »
Nope, you need the tunnel out of the 4x4 unless you run a body lift.
