The Highs (Raising/Lifts)
4 inch lift
Topic: 4 inch lift (Read 6327 times)
4x4HighSierra
Sqaure body stud
4 inch lift
January 31, 2010, 09:23:34 pm »
hey everyone i am getting ready to put a 4 inch suspension lift on my 85 GMC k10 High Sierra lwb. I was wondering besides the brake lines and steering arm if the front and rear drive shaft would have to be longer. The only reason i want the lift is so the 33 pro comp m/t's will stop rubbing and tearing my fender trim up. That and i have always wanted a truck with some kind of lift.
http://www.facebook.com/photo.php?pid=603993&id=1097512330
1985 GMC High Sierra K10 mild 350 and rebuilt 700R4 with transgo shift kit
1985 GMC Sierra Classic C10 TPI 350 swapped in and 700R4 and 6 inch drop, with front drop spindles and a axle flip in the back and c notched frame
1995 Chevy Tahoe LT stock
choptop
Extended cab fanatic
Re: 4 inch lift
January 31, 2010, 09:27:30 pm »
I dont believe the driveshafts will be an issue with the 4 inch lift. Many are running 6 inch lifts with stock drivelines. you should be fine.
4x4HighSierra
Sqaure body stud
Re: 4 inch lift
January 31, 2010, 09:39:12 pm »
thats good on my part and thanks for the info
Re: 4 inch lift
February 01, 2010, 04:02:59 am »
x2 I'm running stock on my 6" but I'm pushing it
4 inch lift
