Author Topic: oil pressure gauge not working  (Read 61992 times)
Offline kbw87
« on: January 31, 2010, 11:38:21 pm »
I've got an 87' with an oil pressure gauge that is pegged all the way to the right.  Does anyone know if this is a sensor issue or gauge?
Thanks
Offline 4x4HighSierra
  • Sqaure body stud
Re: oil pressure gauge not working
« Reply #1 on: January 31, 2010, 11:50:37 pm »
Most likely the sending unit behind the distributor on the drivers side has gone bad.  Or it has come unplugged and is grounding itself out causing the gauge to peg itself.
1985 GMC High Sierra K10 mild 350 and rebuilt 700R4 with transgo shift kit
1985 GMC Sierra Classic C10 TPI 350 swapped in and 700R4 and 6 inch drop, with front drop spindles and a axle flip in the back and c notched frame
1995 Chevy Tahoe LT stock
« Reply #2 on: February 01, 2010, 03:54:52 am »
does it do this with the key on or off? if it stays pegged out it would be the gauge if it does this when you turn the key on it should be the sending unit
Offline ohio hab
  • 1984 C-10, 383 SBC
« Reply #3 on: February 01, 2010, 05:53:44 pm »
I once  had this problem on my 84 C-10, and the problem was caused by dirt, sludge, in the sending unit.
« Reply #4 on: February 01, 2010, 06:13:02 pm »
check the connection at the sending unit first.
Offline kbw87
« Reply #5 on: February 01, 2010, 07:29:36 pm »
I was assuming the sending unit was the sensor that threads directly into the block.  I did pull this wire and check the connection to and no luck.
The gauge stays pegged to the right key on/key off.
I haven't pulled the dash panel off yet to check anything with the gauge yet.  Maybe i'll pull the gauge then.
« Reply #6 on: February 01, 2010, 11:45:44 pm »
Did you check the oil pressure switch or the oil pressure sending unit?
« Reply #7 on: February 02, 2010, 04:47:04 am »
going with vile it almost sounds like you just said you tested the switch on the side of the block the sending unit is in the intake manifold behind the distributor
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #8 on: February 02, 2010, 02:34:57 pm »
I broke the connector on my sending unit while doing a tune up.  it stays pegged all the way to the right at about 2:00.  I'd get a new sender.
an 87 has 2 oil psi sensors.  It's the big soup can looking one by the oil filter is for the gauge.  On the older trucks the big can shaped one is up by the intake.
Offline kbw87
« Reply #9 on: February 02, 2010, 07:53:15 pm »
Good pic - great info.
I didn't realize there was 2 sensors.  I had only been looking by the exhaust manifold.  My gauge is in that 2:00 position as well.  I will check the connection first thing tomorrow and start there.
Thanks for the help guys.
« Last Edit: February 02, 2010, 09:19:37 pm by kbw87 »
Offline Layne
« Reply #10 on: February 02, 2010, 08:09:06 pm »
Don't mean to butt in here, but which one would you hook up a mechanical guage to? IE Autometer?
« Reply #11 on: February 02, 2010, 11:40:15 pm »
A mechanical gauge would require you to run a direct line from any oil gallery tap.
« Reply #12 on: February 03, 2010, 01:50:45 am »
most time with mechanical gauge people just remove the sending unit but the distr. and replace it with the hose and fittings the gauge comes with
Offline Layne
« Reply #13 on: February 03, 2010, 03:50:33 pm »
I TEE'd into the one on the citation. Figured I'd do that. but didn't know which one would be better or if I can just remove one or the other and tap in...
Offline frito-bandito
  • Hillbilly Deluxe
« Reply #14 on: February 03, 2010, 06:23:42 pm »
I always hook up mechanical oil gauges to the one by the distributor just because its closest to the firewall, but furthest away from exhaust manifolds or steering shafts.
