Author Topic: fuel line size?  (Read 18913 times)
Offline bigred
fuel line size?
« on: February 10, 2010, 04:23:43 pm »
What a size are the supply and return fuel lines for 87 tbi engine? 3/8 and 5/16? thanks
Re: fuel line size?
« Reply #1 on: February 10, 2010, 05:47:16 pm »
yes.
Re: fuel line size?
« Reply #2 on: February 10, 2010, 06:29:16 pm »
Which lines do you need? I have the GM part #'s for the TBI flex lines
Offline bigred
Re: fuel line size?
« Reply #3 on: February 11, 2010, 12:13:32 am »
I have a short section of rubber hose just before you get to the tbi. I added a fuel pressure guage a few yrs ago ended up cutting the line and spliced with it with rubber. I"m getting ready to put  a new engine in and since it will use a higher flow fuel pump I was going to couple the fuel supply line back together with steel line. Iknow should have did that to begin with ha!
Re: fuel line size?
« Reply #4 on: February 11, 2010, 10:35:56 am »
If you want the GM part #'s they are 15548993 Return and 15548991 Feed
