Author Topic: Gear lube  (Read 3234 times)
Offline 82gmc3/4ton
Gear lube
« on: March 31, 2010, 07:24:51 am »
I was wondering what gear lube you guys are using in your axles? What do you guys suggest? I haven't had any problems but I want to change for maintenance. I currently have a front 10 bolt GM and a 14 bolt 9.5 semi-float GM rearend. Thanks
Re: Gear lube
« Reply #1 on: March 31, 2010, 07:58:11 am »
80w90 is what they called for
Offline 82gmc3/4ton
Re: Gear lube
« Reply #2 on: April 01, 2010, 07:01:01 am »
Thanks Vile. Is there a brand or synthetic that you use or are they mostly the same stuff?
Re: Gear lube
« Reply #3 on: April 02, 2010, 10:38:13 am »
I wouldn't bother with synthetic unless you're pouncing on it. I have no preference on brand for stock applications
