Author Topic: still smokin! :(  (Read 11388 times)
Offline screamin86
still smokin! :(
« on: April 21, 2010, 04:22:47 pm »
Well I've thought of every possibility and tried a few things and I'm stll getting smoke and can't pinpoint what it is! After I replaced the dizzy with one with new cap coil rotor and light weight springs it almost quit smoking completely. When I added a new fuel pump because the old one was leaking back it holds fuel better after turned off but now it smokes worse! Its not black smoke its almost white/blueish gray but smells like fuel! I'm stumped! :/ plugs don't look bad either! I'm gona reshoot timming and check fuel pressure again. Wost case scenario ima pull the heads and go through them. If I pull the pcv valve it doesn't some so not really any blow by. I've got 600miles on it all and its driving me insane!
86 ta:lm7 hot cam boltons
Re: still smokin! :(
« Reply #1 on: April 21, 2010, 08:09:13 pm »
What trans do you have? If it's a THM350 or THM400 pull the vacuum hose off of the modulator and check for ATF
Offline screamin86
« Reply #2 on: April 21, 2010, 08:15:44 pm »
Its a summit racing th350.
« Reply #3 on: April 21, 2010, 08:19:25 pm »
OK check the modulator. Remove the hose and plug it. See if ATF drips out of the trans and see if the smoking stops
Offline screamin86
« Reply #4 on: April 21, 2010, 09:30:37 pm »
Ill try that before I leave work tonight.
Offline screamin86
possible leaking headgasket
« Reply #5 on: May 14, 2010, 01:39:38 pm »
well after scratching my head for the past month or so on my truck smoking its progressivly gotten worse ive added a fuel pressure regulator and t helped the fuel smell but im still getting smoke so i went and ordered a new set of headgaskets from advanced today and i plan to pull the heads off tomarrow and change them out and install my performer rpm intake. i was gona wait another week but the wife told me she volunteered me to move one of her friends next weekend so im gona bite the bullet and do it all this weekend. here is a video of whats going on. dont mind the wondering needle on my fuel psi gauge thats what i get for not buying a liquid filled one.
http://www.youtube.com/watch?v=Osk5Cbwozm8
Offline Hertzdaddy
Re: possible leaking headgasket
« Reply #6 on: May 14, 2010, 02:39:49 pm »
You've eliminated bad rings and/or leaky valve seals as a possibility? It doesn't look like a head gasket issue to me.
Offline screamin86
« Reply #7 on: May 14, 2010, 02:45:21 pm »
I'm not getting any blow by from the valve cover breather or when I pull the pcv valve out not finding any oil deposits on my plugs other than a lil soot from when I was running almost 7lbs of fuel pressure.
« Reply #8 on: May 14, 2010, 05:20:42 pm »
Is it using coolant?
Offline screamin86
« Reply #9 on: May 14, 2010, 05:23:29 pm »
I've noticed a slight drop in the coolant level in my overflow tank over the past month. But no water in the oil or oil in the water.
« Reply #10 on: May 14, 2010, 05:24:22 pm »
So why do you think you have bad headgaskets?
« Reply #11 on: May 14, 2010, 05:29:21 pm »
I merged your posts because you really should continue from the original post.
Did you ever check the modulator?
Offline screamin86
« Reply #12 on: May 14, 2010, 06:03:04 pm »
Sorry about that I had forgot about this post. Well like I said I am noticing a small loss of coolant but no mixing and I am going to change the intake and figure if I'm that far along ill do the heads to be safe. Every now and then I can smell antifreeze if the truck has been sitting for a few days.
Offline Josh454
« Reply #13 on: May 14, 2010, 06:40:12 pm »
Doesn't sound like head gaskets at all to me.  If you have ruled out the trans modulator...have you verified that it's not running extremely rich?  Other than that I would wonder about a cracked ring or piston.
Offline screamin86
« Reply #14 on: May 14, 2010, 06:53:54 pm »
I think that I'm going to check out the valve seals before I pull the heads. I've got a set of valve springs to put on anyway. It never smoked in the first 100miles until it got hot on me then since I've had the issues. It runs great and doesn't miss a beat it just smokes at idle and doesn't seem to "load up" at all.
