Author Topic: axle codes to rear end ratio?  (Read 21775 times)
Offline fbody
    • firebird and camaro
« on: April 22, 2010, 02:24:36 pm »
anyone have a link to axle codes.. i know it is stamped on the tube, but where is the link that shows the code and then what rear end ratio that is?  thanks
Offline fbody
Re: axle codes to rear end ratio?
« Reply #1 on: April 22, 2010, 02:35:53 pm »
side note, i did look at 73-87.com, those rpo codes do not go as far back as 73.
mine, 73 C20, 3/4 ton, 454.  14 bolt.
« Reply #2 on: April 22, 2010, 06:56:07 pm »
Your only way to know for sure is to take the cover off and look what is stamped on the ring gear.  37 years have gone by and someone might have changed it out.  My $.02
« Reply #3 on: April 22, 2010, 07:48:39 pm »
probably need to change the oil anyway. Ive pulled the cover on 3 of them in the last day or so, and they all showed cruddy oil with signs or water. (Milky)
Offline fbody
« Reply #5 on: April 22, 2010, 11:13:32 pm »
true on the oil change.  yea, i was scraping all sides of the axle tubes looking or stamped number.. nothing!  oh well, will pull cover and check there.
Offline fbody
« Reply #6 on: May 03, 2010, 08:44:43 pm »
found it.  code FD.. now I cannot find a link with that code on it.  anyone have any ideas or a book?
Offline fbody
Re: axle codes to rear end ratio? TFD in a 14 bolt
« Reply #7 on: May 03, 2010, 11:21:04 pm »
well shoot, i scraped off more junk.. code is actually TFD
Offline The Lady In Red
« Reply #8 on: May 04, 2010, 09:55:14 pm »
Zieg is right... only way to know for sure.  However FYI, these are the codes available for your truck in '73:
3.21  (OPT HC8)
3.23  (OPT GU5)
3.42  (OPT GU6)
3.73  (OPT GT4)
4.10  (OPT GT5)
