Author Topic: I dont know what happened...  (Read 14282 times)
Offline 74k20
Re: I dont know what happened...
« Reply #15 on: May 02, 2010, 06:39:09 pm »
When you stated you took out the Mile Marker kit and output shaft, did you mean temporarily or did you put the full time stuff back in?  I've been keeping an eye on your progress.  Congrats and lets hope it's all better now.  Good luck.
Offline frickenbored
  • 383 Beast
« Reply #16 on: May 02, 2010, 07:34:24 pm »
What I did was dissasemble the rear of the tcase so I could see what was goint on then I put a hose clamp on that shaft to keep the spacer in place so the needle bearings wouldnt come out and then I ran the truck in reverse.  The mile marker kit had nothing to do with this problem.
Offline treny
    • 83C10
« Reply #17 on: June 19, 2010, 02:40:52 pm »
I had the same thing happen only I was changing the motor and trannie..I took it to the trannie shop and they put a new pump in it , they said the torque convertor wasnt full and it took out the pump , its fine 600.oo later  haha  was also a th400
Bruce Treny
Hii There , Stating another project , an 83 c10 2wd  .Frame etc is all good and have to replace dash pad and seat , some body work and Paint Prob flat blk wth a clear cote to seal it.Ill keep in touch with updates ..Bruce
