Author Topic: what t case for 4wd nv4500  (Read 6238 times)
Offline heavychevy
« on: May 12, 2010, 05:26:24 pm »
im in tha process of puttin a 93 model nv4500 which has the 6.34 low in my 85 1/2 ton 4x4 ,does any body know what t case has the round 6 hole pattern and matching spline shaft for it . i tried the stock np208 and its shaft is too small  for the 4500
Offline Josh454
Re: what t case for 4wd nv4500
« Reply #1 on: May 12, 2010, 07:17:47 pm »
Is it a 27 spline?  If it is it you may need a different adapter...
Offline heavychevy
« Reply #2 on: May 14, 2010, 12:19:52 am »
no its a 32 spline i think i need a right hand 241 maybe i cant find out much info on em such as wat splines they are my 4500 came with a 241c
Offline seasno
« Reply #3 on: July 16, 2010, 07:54:14 pm »
you need a NP205 with a 32 spline count to work with a NV4500.
Offline blazinzuk
« Reply #4 on: July 19, 2010, 06:21:32 pm »
Only a round pattern.  Also a round pattern 241 will work so will a round pattern 208.  I have done the 208 and the 241 is pretty much the same as far as mounting it goes
« Reply #5 on: July 24, 2010, 12:02:31 am »
TH 400 or SM465 NP 208 will work. The one you have is for a 700R4, or a TH 350.
