Author Topic: Headlight restore  (Read 4790 times)
Headlight restore
« on: June 06, 2010, 07:17:39 pm »
Finally got around to cleaning up my headlights. Thought I would share and possibly encourage anyone to get it done. I used 1500 and then 2000 grit wet sandpaper and then finished up with Meguiar's PlastX. They have a kit, but it was cheaper to buy just the bottle, sandpaper and foam pad separately. I do wish that I had bought the rotary pad though...
Before
After
Re: Headlight restore
« Reply #1 on: June 06, 2010, 09:05:33 pm »
I use the 3M kits and they work mint
« Reply #2 on: June 06, 2010, 09:37:04 pm »
Did this to a 46 foot diesel pusher motor home last week. Some mouth breather had painted the front of it, then peeled the tape off and clear coated over the head lights. DOH  ::)
 So I sanded them with 400 dry first, then 600, then, 800, then 1200, then 1500 wet. Then I used 3Ms headlight compound. it did OK. Then I used 3M micro finishing compound. That worked allot better.
« Reply #3 on: June 06, 2010, 11:07:29 pm »
I saw the 3M kit, was thinking about getting it. Turned out good enough for the mean time. End of summer I'll probably do it again.
« Reply #4 on: June 07, 2010, 06:26:32 am »
Snap on makes a nice kit with a air tool, wheels, and all the crap to go with it. Like $130.00
« Reply #5 on: June 07, 2010, 12:16:57 pm »
Wow thats crazy.
« Reply #6 on: June 07, 2010, 04:57:55 pm »
« Reply #7 on: June 07, 2010, 10:14:04 pm »
Thats the kit I got and it sucked.
« Reply #8 on: June 07, 2010, 11:26:01 pm »
I use them all the time and they come out mint.
« Reply #9 on: June 08, 2010, 06:04:31 pm »
I ended up using my 3' DA with the grits I mentioned above. Then I tried buffing them with the pad from the kit and the juice they send. The Micro Finishing compound worked way better.
