Brakes and Braking Systems
parking brake light always on
Topic: parking brake light always on (Read 6068 times)
CoreyLEO223
June 09, 2010, 11:59:59 pm »
My parking brake light doesn't turn off when the parking brake is disengaged? Whats up with this, anyone know?
beastie_3
Josh
Re: parking brake light always on
June 10, 2010, 12:08:25 am »
Look for the switch on your parking brake lever and see if it is disengaging or not. Release the parking brake to relieve the pressure on the switch and see if you can pull out the end that should pop out.
Semper Fi
jaredts
June 10, 2010, 05:06:41 am »
I know this is too obvious but have you pulled the release and lifted up on the pedal with your foot? I think the combination valve under the hood can also cause the brake light on the dash to be on.
June 10, 2010, 06:41:40 am »
Yes it can. If you unplug it and it goes out you know that's what's turning it on.
⌠ŻŻŻŻŻ' [☼===☼]
topp
June 10, 2010, 07:49:19 am »
Quote from: VileZambonie on June 10, 2010, 06:41:40 am
And after that, check your brakes. That light is a warning light that your brakes are low.
'90 Suburban TBI 350
