Author Topic: 84 C10 Project  (Read 15083 times)
Offline markdilljr
  • Me on Hopper "Covered"
Re: 84 C10 Project
« Reply #15 on: August 04, 2010, 11:15:50 pm »
Sorry it took so long to answer just got done moving, I removed two leafs out of the rear springs. Up front it had lifted 1 ton springs which sat so high the upper control arm was resting against the spring pocket so I cut 2 coils out of them to drop the front for now. It lowered it from stock 1.5/2, I am going to add 2 inch shackles to the rear for a total of 4 and putting 2.5 inch drop spindles in the front with stock springs, if the front is not low enough I can put in 1 inch drop springs for a total of 3.5. I still want a slightly raked look
Ride Rank, Make Bank
