Author Topic: 496 STROKER INJECTED  (Read 10775 times)
Offline 123 pugsy
« on: June 28, 2010, 05:10:14 pm »
Hi Guys. Its been a while. I'm still around checking in every now and then.
I figured this would be a good forum for discussing an injected big block as they are truck engines.
I'm thinking of stroking a GEN VI 454 to 496 and using the Vortec intake.
I'd like to get over 500 LBS/FT of torque and close to 500HP.
Does anyone know if this is doable with this intake?
I was thinking of using GMPP aluminum heads. a higher lift cam and about 10:1 comp ratio .
Any thoughts on this?
Oh yeah...here's a peak of where I'm at with the ROD.....
Thanks,
Pugsy
76 C10 LWB
TPI 350
Re: 496 STROKER INJECTED
« Reply #1 on: June 28, 2010, 10:10:44 pm »
I think it is doable especially with a BBC.
Offline 123 pugsy
« Reply #2 on: June 29, 2010, 05:11:00 am »
How about the stock wiring and ECM from a donor truck? I'd like to run a 4L80E as well.
I guess I would need bigger injectors. Can the stock computer run these or is there some kind of reprogramming available?
Pugsy
76 C10 LWB
TPI 350
Offline team39763
« Reply #3 on: June 30, 2010, 09:39:35 am »
500hp?....Dude you'll knock that figure out of the park easily with nice aluminum heads.    I don't know anything about that intake though.  That car is awesome.
Offline 123 pugsy
« Reply #4 on: June 30, 2010, 11:53:25 am »
Thanks.
Its the intake that has me worried.
I've read about modifying the upper half but haven't seen anything on how its done.
I also saw on ebay a 78 mm throttle body for it but its only like 3mm bigger than stock.
Hate to put it all together and found I've built a dog.
Pugsy
76 C10 LWB
TPI 350
« Reply #5 on: June 30, 2010, 04:55:23 pm »
We are blowing 17lbs down a stock 6.0L plastic intake with a slightly bored Throttle body and making 500+.   I think the stock intake will handle it.  The heads are the restriction  Get some off a 502 (Mark V)  or these: http://www.raylarengine.com/cylinder_head.html
I don't think you could put a 8.1L together and NOT make good power.  I would use the ECM also, just have it tuned.
Offline team39763
« Reply #6 on: July 01, 2010, 09:26:35 pm »
Is this a Vortec 454?  Couldn't you buy an aftermarket aluminum intake with injector bosses and use an adapter or 4bbl throttlebody?  I think that's what they reccommend on the 454ss site for the TBI guys.  Then you'd need a new tune on the ECM.  That's also what some are doing with the LS motors too.
Offline 123 pugsy
« Reply #7 on: July 04, 2010, 08:29:55 am »
Yes, its a 7.4 Vortec.
I like the aftermarket stuff, but I'm trying to build on a bit of a budget.
The GM heads are the best price I could find for aluminum heads complete. They are the same ones used on the 502 crate engines.
http://paceperformance.com/index.asp?PageAction=VIEWPROD&ProdID=22500
I'm planning on using a GearVendors unit behind the 4L80E to hopefully pull off some decent mileage at cruise.
Ya, I know, a big block and good mileage don't mix.   ::)
Pugsy
76 C10 LWB
TPI 350
Offline team39763
« Reply #8 on: July 05, 2010, 12:48:43 am »
I've read good things about those heads.  Maybe you could have that intake ported and matched to your heads.  I know a few places that will do port matching of the intake for around $150.  The LS guys are all over the throttlebody upgrades...bigger ones, ported ones, and tricked out ones....so maybe it's worth a try.
