Author Topic: Socket size for ball joints  (Read 6705 times)
Offline 82gmc3/4ton
« on: June 29, 2010, 06:52:00 pm »
Can someone tell me what size sockets are used to remove the nuts off of the upper and lower ball joints?
Thanks
Re: Socket size for ball joints
« Reply #1 on: June 29, 2010, 07:03:23 pm »
It could be different depending on if they are original, or after market. I have found over the years that aftermarket one tend to use a larger nut.Use a tape and messure across the nut.
Offline thirsty
    • Suitor's Garage
« Reply #2 on: June 30, 2010, 07:38:36 am »
Mine where 1"5/16
Offline 82gmc3/4ton
« Reply #3 on: July 02, 2010, 08:17:42 pm »
I heard they could be metric. 33mm or something along those lines. I just don't want to buy sockets that won't fit seeing that I'll have to buy them individually
« Reply #4 on: July 02, 2010, 08:55:50 pm »
Your best bet would be to use a ruler, or tape and messure them.
« Reply #5 on: July 03, 2010, 12:32:47 am »
do what blaz said messure them then go out and buy individual sockets from sears or a parts store and before you take the plastic off the sockets see which one fits with least slop and return the others you didn't use just make sure there not dirty
Offline Canadian 4X4
« Reply #6 on: July 03, 2010, 07:17:23 am »
I work on a lot of transport trucks and the lug nuts are 33mm but we use a 1 5/16 all the time they are very close in size.
