Author Topic: Bucket seat conversion  (Read 73067 times)
Offline broke350
« on: July 30, 2010, 11:44:31 am »
I bought a set of buckets out of a mid 80's Blazer at a swap meet, but it seems the floor pan for a 79 pickup and the blazer are different.  Is there a set of buckets that will work, or maybe some frames I can put on these seats to work in my pickup?
Just saw this thread http://forum.73-87chevytrucks.com/smforum/index.php?topic=16934.0
I know a guy with a late 80's/early 90's suburban that wanted to trade for my bench but the bucket seats were the same as my blazer seats and wouldn't work.  Any more specifics on the correct seat frames I need?
« Last Edit: July 30, 2010, 11:49:30 am by broke350 »
'79 SWB 4X4
Offline broke350
Re: Bucket seat conversion
« Reply #2 on: August 02, 2010, 08:51:22 pm »
Thanks for the links.  I pulled up the street beat customs website and it lists two options, one of which has "drill" in the title.  Both say they fit the Corbeau seats.  Should I assume they also fit the factory buckets I have?
http://www.streetbeatcustoms.com/1979/Chevy/K1500-PICKUP/Car-Interior-Parts/Seat-Brackets/
'79 SWB 4X4
« Reply #3 on: August 02, 2010, 08:53:09 pm »
Don't assume anything. Call or email them and ask.
Offline broke350
« Reply #4 on: August 02, 2010, 09:59:53 pm »
Good point.  I'll be calling Corbeau in the morning and will post my finding in case any other members want to know.
'79 SWB 4X4
Offline broke350
« Reply #5 on: August 03, 2010, 10:44:25 am »
Just spoke to the people at Corbeau and they say they will not work with the factory seats, only with their Corbeau seats.
'79 SWB 4X4
« Reply #6 on: August 03, 2010, 06:53:04 pm »
You need Suburban bucket seat brackets and the inner mounts.
Offline broke350
« Reply #7 on: August 03, 2010, 07:44:13 pm »
Thanks for the info.  I had a guy I tried to trade my bench for his buckets out of his suburban, but the seats were exactly the same as my Blazer seats that mounted flat in the back instead of angled to match the floor pan.  So I will be hitting the junk yards to see if I can find the right brackets and mounts.  In your other post you said the mounts are welded to the floor.  Does this mean I will need to cut and weld in the new front mounts, or am I reading too much into your post?  Sorry for beating this topic to death.
'79 SWB 4X4
« Reply #8 on: August 12, 2010, 06:20:40 pm »
The 84-91 suburban seat bracket WILL fit a 73-87.  Just bend the rear mount up to match the floor.
The inner mounts are welded to the floor, you will have to remove them with a spot weld cutter or a chisel.
« Last Edit: February 22, 2012, 09:47:17 pm by Captkaos »
Offline Swims350
    • Cars and trucks
« Reply #9 on: August 12, 2010, 08:27:35 pm »
for a truck can't you just use 2 sets of bench seat tracks for buckets?
www.cardomain.com/id/benwa454
Offline broke350
« Reply #10 on: December 21, 2010, 10:58:32 pm »
Back from the dead.  Just wanted to post another possible solution.  Has anyone heard good/bad things about the scat/procar seats and brackets?  These are the seats I'm looking at, but of course they have other color combos.
http://www.summitracing.com/parts/SCA-80-1606-64L/?rtype=10
http://www.summitracing.com/parts/SCA-81196/Application/?query=Year%7c1979%7cMake%7cCHEVROLET%7cModel%7cK10&prefilter=1
Seats and brackets for ~$485.00 shipped seems much better than the $800.00+ for the Corbeau's.  I understand these are vinyl/velour where the Corbeau's are cloth and leather.
'79 SWB 4X4
Offline 84nickle350
« Reply #11 on: December 22, 2010, 06:37:39 pm »
ill take pictures of my buckets, they wont match the rest of the interior till i have them recoverd but paid 150 at the local junk yard for them and they are out of a 1997 ford f150 and boy are they comfy plus they sit alittle higher than stock i LOVE them all i needed was a drill and a center punch and a 3/8 drill bit and they look like they belong in there
Offline broke350
« Reply #12 on: December 22, 2010, 10:59:25 pm »
Thanks, I'd like to see them.  There's a local guy parting out a 76 with buckets already in it.  Planning on stopping by tomorrow to see what seats and brackets he's got.
'79 SWB 4X4
Offline Skunksmash
« Reply #13 on: December 23, 2010, 06:34:32 am »
This question gets asked a lot. Might be worth creating a sticky dedicated to it.
