Author Topic: 198-Everything K10 Diesel Project (Bunch of pictures!)  (Read 33355 times)
Offline Altec
  • Custom De-Luxe
« on: August 03, 2010, 01:15:37 am »
Building a mix-matched truck from a bunch of 80's chevy trucks, Blazers, and one 1991 'burban. Oh, and a '95 Vandura for a 6.5NA diesel.
Basic run down.
-----Sheet Metal-----
1986 Short-Bread K10 Frame
1986 Short-Bread K10 Cab
1986 Short-Bread K10 Bed
1991 Suburban Doors
1991 Suburban Front-Clip
LUND Cab Spoiler
LUND Cab Visor
-----Running Gear-----
12-Bolt Axle (From a 1976 Blazer)
3.73 Gears/Posi
10-Bolt (From the same '86 K10)
3.73 Gears/WARN Hubs
NP208 Transfer Case (From a 198X Blazer)
SM465 Transmission (From the same 198X Blazer)
Late-Style Mechanical Clutch (Same Blazer...)
6.5L HO N/A V8 Diesel L57-Y (From a 1995 Vandura 3500)
What I started with. Frame broken around the steering box. Steering column missing, dash tore up... Had a factory 305SB/700R4 setup. Both gone...
In the shop, and the front clip removed.
Pile-O-Parts
Got it on the lift, and removed the transmission. Removed the transfer case first. Then cut the exhaust out, and finally dropped the tranny.
Then went at the bed. It had a plastic liner in it. My worst enemy! Lucky for me though the bed was clean under it!
Next was the bolts holding the bed. I held them down with a board while my Dad tried to get the nuts off. Most all of them spun, so we had to torch the bolts off.
I seem to have a lack of truck bed in this general area...
Pulled the engine next.
Next some penetrating oil on the leaf spring bolts. I swapped the front leafs, and swapped the entire rear axle.
Settled for blocks until I can get leafs. I'm probably going to end up doing a shackle flip. That'll be the same time I go 3/4 ton.
I had planned to use a 350SB I had laying around until I got the 6.5. At this point in my working I went ahead and started on the 350. I pulled it out of a '83 Scottsdale 3/4 ton. I pulled the heads, and the engine looked like butter. Still see the hash marks from when it was rebuilt! Gonna keep this engine for later.
After this I pretty much stopped for a couple months. But one evening I was bored and went out and did a little work. Not much, just painted the firewall, and trimmed the junk I don't need.
Next I went to work on the cab. Took the bench out, and stripped EVERYTHING. Someone beat me to the dash, so all I had left was the cluster, and what was left of the dash pad.
Found under the seat belt bracket...
All the panels I took out (Anybody need anything?)
After I was done. I got a vinyl mat to go on the floor, and I'm not putting any of the pieces back. Trying to make it more like my dads Custom Deluxe.
I had watched Zombieland before working on the truck...
The frame after sealing. I had wire wheeled it before. Still needs painted.
My truck grew another pedal. I mounted the clutch pedal, and mounted the bell crank arm to the frame. It was off a Blazer. I hammered out the old rivets, and bolted it to the frame. Chevrolet was nice enough to put the holes in the frame already. Made it easier for both of us.
Although these tires aren't staying, I need them to roll it around. But the driver-rear kept going flat. With some soap I found it was the bead. So the tire was put on the machine, and the bead broken. I then wire brushed both the wheel, and tire to clean it. After this some spray glue around the bead. Aired it back up, and no problems since.
I completed the front area by doing the top-area-thingy (The proper name slips my mind). Took the wipers, and the grill off. Then the plastic piece. Used a shop vac to clean up all the junk. Including a mouse nest. Then I painted the sheet metal. I then painted the metal grill, but haven't uploaded the pictures. Sorry.
As the truck sits. Next on the list is to get the column out of the donor, and pull the 6.5 from the van.
Here is a picture of the front clip I'll be using.
And the doors.
And that is what is done up to date. The final truck will be with the above specs. Flat black paint, and a single off-set 6" stack. Still deciding on tires. Lots left to do, but I'm working on it! I need to order new outer rockers, and cab corners. Wonder where I can get them?  ;D
1981 K10 Short Bread - 6.5NA - SM465
Offline Layne
Re: 198-Everything K10 Diesel Project (Bunch of pictures!)
« Reply #1 on: August 03, 2010, 01:19:21 am »
Welcome! Cool project, keep us updated!
« Reply #2 on: August 03, 2010, 01:34:04 am »
sweet!
Offline Corkey723
« Reply #3 on: August 03, 2010, 10:11:47 am »
Hey, you wouldnt by chance have a good drivers side longbed bedside you would be willing to sell. Im looking for one.
The truck looks like its gonna be sweet when its done. I wouldnt mind a Diesel swap in the future on mine.
Offline Altec
  • Custom De-Luxe
« Reply #4 on: August 03, 2010, 12:38:22 pm »
Layne- Thank you. I will.
Beastie-  :)
Thanks! Diesel's are my first love! Down the road I wouldn't mind finding a 4-92 Detroit 2-Stroke.
« Last Edit: August 03, 2010, 01:44:31 pm by Altec »
Offline Engineer
« Reply #5 on: August 04, 2010, 06:20:08 pm »
OMG!
Please don't ruin that gem by putting the Lund visor on it!!!
Vile! where are you at buddy, I need you to watch my back on this one!
Don't let the O.P. ruin his truck!  :o
......Otherwise it looks like a cool build.  :)
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline Altec
  • Custom De-Luxe
« Reply #6 on: August 05, 2010, 02:22:06 pm »
I love my visor.  :)
Oh- Yesterday dodging snakes, spiders, and rust I got the steering column out of the donor. That turning into way more of a job then it should have... Pictures later!
« Last Edit: August 05, 2010, 02:23:41 pm by Altec »
Offline Altec
  • Custom De-Luxe
« Reply #7 on: August 05, 2010, 06:12:55 pm »
Update, nothing amazing. I painted the grill piece, and got it back on. Today I put the column in. I don't need a ratchet to steer anymore!
Gotta do something about that shifter. :devious:
Offline 84chevysilverado
« Reply #8 on: August 07, 2010, 09:04:37 am »
nice project lots of potential thare :)
Offline Altec
  • Custom De-Luxe
« Reply #9 on: August 09, 2010, 12:56:18 pm »
No real updates. The only thing I've really done is redo the center jewel on the steering wheel.
I have confirmed a pair of '06 Silverado seats for the truck. :) I'm just going to have to make a mounting setup for them. Which is a piece of cake. I also might have a newer plastic fuel tank, and a large rad that I might try to adapt. Depending on if I can make them fit. I know the tank is to big to fit in the original saddle-bag style, but I may just stuff it in the bed. Dunno yet. The rad will be down to height. If it isn't to tall, I'll use it. Otherwise I have a Big Block one that will work.
I went back on my uncles farm to find this detroit. Turned out to only be a 3-53. But he may have another back there, so I'm going hunting later this evening. I really want a 4-71 or 4-92.
And now I also have a propane itch I need to scratch. So whatever engine that goes into this will also be getting a propane injection. Just to try pretty much. I'm really not into this stuff normally.
Offline Altec
  • Custom De-Luxe
« Reply #10 on: August 26, 2010, 06:15:36 pm »
Well, not exactly setting any speed records but with a few free moments here, and there I getting along.
I took the dash out of my donor for the truck, and sat it in it to see how it fit. Little inspiration as well. When I was taking the cluster out I realized I did a stupid while getting the steering column out. I cut the line for my mechanical Sport-Comp water temperature gauge... So I'm going to add that to my list of gauges I need to buy. Next to a EGT, and fuel level gauge. Why a fuel level gauge? Because I'm pulling the factory speedo, and fuel gauge. To be replaced by a Pro-Comp speedo, and tach. I'm considering replacing all my gauges with Pro-Comp's. To have a matching set. Save the Sport-Comps for another day. If anyone is wondering. I'm making the tach work with a Dakota Digital tach sensor. Simply because it is a cheaper option then buying Pro-Comp Diesel Tach.
The Sport-Comp's were already added by my Dad. He did this with a 5" tach mounted to the steering column. I'm simply pulling the last of the stock gauges.
My Dad's cluster.
http://i13.photobucket.com/albums/a269/Mrjunior/Truck%20Project/100_6004.jpg
http://i13.photobucket.com/albums/a269/Mrjunior/Truck%20Project/100_6005.jpg
Starting to paint the inside of the cab. It is simply rattle can bed liner I found at Home Depot.
Started painting the frame today. It is brushed on Hammered finish paint. Goes on thick, which is what I wanted. I know a few guys running trucks with this with no problems. Still need to paint the inside of the rails, and the underside. I need to rip some old lines out before the inside can be done. If you are wondering, the frame is going to be painted, the sheet metal undercoated. Not painting the springs, or axles until I've got them all buttoned up.
« Reply #11 on: August 26, 2010, 06:22:52 pm »
Looking good!
You should be able to get a new line for your gauge, instead of buying a new one.
Offline Altec
  • Custom De-Luxe
« Reply #12 on: August 26, 2010, 06:38:20 pm »
Thanks.  :)
I wish I could.  :'( The line is filled with gas though. It is a sealed system. I can send it back to Autometer I believe. Not sure how much that would cost. I figure it is most likely cheaper then a new gauge. Since I'm considering running all Pro-Comp's, I'm not to concerned at the moment. Still kicking myself though...
Offline Altec
  • Custom De-Luxe
« Reply #13 on: August 30, 2010, 12:29:41 pm »
Nothing fancy. Just a small update. I painted the front section of frame. Modified the dash to accept my 5" gauges. Then I went to a junkyard. Wandering around I found a GMC 'burban with a nice dash still in it. So I popped that out for mine. Cost me $12.  ;D It had a cherry FM radio as well. I'm tempted to go back for it, but I'm a 100% CD person, so IDK. So I'm gonna do the mock up with my old dash, then when I am ready I'll cut the new dash, and put it in.
« Last Edit: August 30, 2010, 12:31:45 pm by Altec »
« Reply #14 on: August 30, 2010, 10:24:04 pm »
Nice. What is the switch for?
