Author Topic: How many miles do you have?  (Read 18268 times)
Offline txchainsawgogi
Re: How many miles do you have?
« Reply #15 on: August 16, 2010, 07:58:17 pm »
My 78 has 90K 8)
Offline fitz
« Reply #16 on: August 16, 2010, 10:44:08 pm »
Chris, you oughta take pics of the steps involved.  I am curious.  The worst part probably is dropping the tank to get to it. I hope you don't have a full tank.
I've seen a few blazers and burbs where someone just cut a hole in the rear floor to get to the pump.
Offline RedEightySix
« Reply #17 on: August 16, 2010, 11:41:38 pm »
I'm jealous of all you guys with less than 100K miles on your oldies...But for being at 148K miles, my truck isn't rusting TOO bad!
« Reply #18 on: August 17, 2010, 01:50:55 pm »
Actually I do plan to take pictures.  If I can swing it I may take some video.
Offline bobcooter
  • 1979 Scottsdale C-20
« Reply #19 on: August 19, 2010, 03:14:46 pm »
My 79 only has 25,000 miles on it...give or take 1 or 2 hundred thousand miles.
Offline 4x4orbust
« Reply #20 on: August 19, 2010, 06:59:25 pm »
i have 135,000 on my 82, though motor, tranny and t-case only have about 5,000.   my old 73 had 66,000 original miles when i got rid of it.
Offline jhcon65
« Reply #21 on: December 14, 2010, 07:02:51 pm »
I know this is an old thread  but I dont post much on  here ....my 87 Silverado  has 407,000 miles original drivetrain completely ! It was my uncles personal truck for his construction comp. for 10 years..... then it got cycled into the mix as a lumber/work truck for another 10/12 years ... I bought it from him for 500.00 and traded a new lumber rack , I have replaced the battery , alternator..of thing that had to be replaced....the rest I did cuz i wanted to ...... paint , scavenged interior from a 89 Sub trim pieces from EVERY WHERE...... tires and wheels from Craigslist 200.00 still runs very good  more reliable than my wifes 97 Sub , with double  her miles !!!! the truck is all original aside from the suburban interior ....
Offline howlinwolf
« Reply #22 on: December 14, 2010, 07:52:24 pm »
around 96000 on my truck,
210xxx on my minivan. (first and only ford ive ever had)
220600 on my 99 lumina.  just did the thermostat in 3 minutes flat.
78 Chevy Custom Deluxe flatbed, PROPANE POWERED
Offline KY..Rob
« Reply #23 on: December 14, 2010, 08:15:37 pm »
Just goes to show, that they will run forever. My 78 K10 had 131.000 on it when I sold it. The 86 C20 had about 245 thousand when it throwed a rod out of the old 305.
Offline jackjeckel757
« Reply #24 on: December 14, 2010, 08:36:03 pm »
Don't exactly know what my '77 C 10 has, it says 28,500 and I figure to add 200K to it. My '04 Monte has 110,000 after many trips to NH and back to VA.
Offline 1979C20
  • Kyle Taulton.
« Reply #25 on: December 15, 2010, 02:53:44 am »
My 79c20 has 63xxx original miles on the truck, and the engine has about 2000 miles on it. The truck sat for ten years before I bought it. The title/registration from 10 years ago says 30xxx. (: arizona truck with AZ rust (slight surface rust). Just an amazing truck. The front suspension was replace about 15 years ago, as it was a work truck and I'm sure it saw a lot of abuse on work roads. And, I think, not sure, but THINK it still has original drums, shoes, rotors, and pads.
Offline Grim 82
« Reply #26 on: December 15, 2010, 08:55:50 am »
My 82 K10 had 38,xxx on it until I swapped the gauge cluster. Now it only has 11,xxx. It's all original except for the motor, trans, t-case, axles, steering column, interior, fuel tanks, front clip and doors. ;D
Offline 87454westernhauler
« Reply #27 on: December 15, 2010, 09:50:02 am »
i have over 400k on my 87 r10 305 manual trany, origional trany and engine has 350k on it runs ok still but body is almost gone on the drivers side of the cab:'( :'(
also have an 87 454 chevy western hauler that has over 600k on it and origional motor in it, but it smokes like a diesel and its gas ::) ::) ::) ::), but it runs good and is a very dependable long miles and daily driver truck for my dad!
79 gmc c20 350 th350
78 k1500 4x4 350 th350
Offline rainman15
  • Steve
« Reply #28 on: December 15, 2010, 02:23:08 pm »
112k on my 84. Original drivetrain front to back. I've done the body work, paint, and changed both gas tanks but nothing mechanically has been changed.
84 GMC High Sierra 4x4 shortbed
09 GMC Sierra SLT
09 Mercedes Benz C-350
60 Chevrolet Impala
Offline polish pete
« Reply #29 on: December 15, 2010, 10:29:43 pm »
i figure i throw this in here but i got 13k orig miles on a 80 gmc  ;D ;D
