Author Topic: Idle compensator problem?  (Read 3829 times)
Offline pewster
« on: August 29, 2010, 07:31:50 pm »
Hello. I have an 81 silverado with only 46k miles and want to restore back up. The a/c system has a throttle solenoid, sometimes called an idle compensator, on the carb linkage that when the a/c compressor clutch engages this thing pushes the throttle up so the engine doesn't stall. It doesn't work anymore and it is an electrical problem. This solenoid itself is vacuum controlled, but an electric valve shifts and causes the vacuum to then go to the solenoid when compressor kicks in. This side of things is good. The electric coil itself is also good. The problem is there is a relay that sends a ground to the coil therefore making everything work properly. The relay itself is good and seems to be maybe a break in a wire leading up to the relay. I just need a good schematic for the truck and I then can figure it out from there. Also a good schematic for the cruise control system too, vacuum and electrical side. Truck is 81 3/4 ton 2 wheel drive with 454 engine. Vin is 1GCGC24W8BJ125938. Thanks
« Last Edit: August 29, 2010, 09:12:52 pm by pewster »
Re: Idle compensator problem?
« Reply #1 on: August 30, 2010, 08:19:17 pm »
Pix
Offline pewster
« Reply #2 on: August 30, 2010, 08:56:46 pm »
Thanks for the reply but these aren't full and complete. I have a factory relay on the drivers' valve cover that works with the idle compensator that isn't on those schematics and the cruise one doesn't even show the control on the fenderwell that has the speedometer cables run to it or the switch on the column so they can't be all there is to it and my truck really has to be complete. I know that the schematics back then weren't very good but even if someone has one and knows for sure what and where the wires and switches do that would help. Thanks
