Performance
radiator hose blew off....
Topic: radiator hose blew off.... (Read 19308 times)
rroeder96
September 06, 2010, 09:01:49 pm »
maybe somebody can give me a little help the bottom hose on my water pump blew off and im wondering if i got a bad water pump or is it the thermastat stuck closed if anybody has any ideas before i start pulling stuff off and just replacing things it would be a big help thanks....
Re: radiator hose blew off....
September 06, 2010, 09:20:28 pm »
I would say it want tight or worked it self free fill it up with water and try it again while you at it test the Rad with a pressure tester
rroeder96
September 06, 2010, 09:29:11 pm »
ok thanks i guess i will replace the hose and clamp fill it back up with a 50/50 mix and hope for the best thanks for the help my brother just said the same thing you did and i trust his judgement as well as anybody i no so thanks for your hep....
78 Chevyrado
Z62 ON-ROAD
Site Supporters
September 06, 2010, 09:44:08 pm »
Did it overheat? if not it's just a problem with the hose.
rroeder96
September 06, 2010, 09:58:53 pm »
no it never overheated it stayed at 170 to 180 which is the norm for that truck ive noticed what are your thoughts
454ss
I WANNA RACE IN A BIGFOOT TRUCK!
September 06, 2010, 10:14:07 pm »
As Irish said, put a pressure tester on it.
How long had the hose been on? I've had worm clamps back off before.
Jay
Searching for my ideal 1973-87 fullsize.
1982 C10 Custom Deluxe stepside - traded
1977 C10 Custom Deluxe longbed - junked
Current:
1991 Chevy S10 Blazer 4x4
1995 Olds Silhouette
2009 Chihuahua
beastie_3
Josh
September 06, 2010, 10:14:47 pm »
Just make sure you clean the water pump opening so the hose can grip it better. Coolant is a little slippery.
Semper Fi
rroeder96
September 06, 2010, 10:48:48 pm »
not sure how long its been on there i just got the truck about two months ago and im still figuring out things on it and still working out all the little problems its had so far but i wouldnt give this truck away for no reason so i will just keep on working on it thanks for all the help...
454ss
September 06, 2010, 11:03:40 pm »
Darn nice looking truck you have!
Jay
Current:
2009 Chihuahua
rroeder96
September 07, 2010, 08:18:53 am »
thanks ive enjoyed everything about it since i had it just gets old having to fix things all the time lol......
bake74
September 10, 2010, 02:14:53 am »
Like mentioned before, pressure check the system, my thought was if you had a plugged rad or problem with water pump, it would have shown on your temp. gauge. Keep us posted on what you find, ok......tom
74 k10, 77k10 Tom
rroeder96
September 10, 2010, 10:10:59 am »
thanks for the info well i replaced the hose with new and new clamps all new fluids and so far everything is working great temp runs around 185 to 195 so i think it will be ok till the next time something goes wrong thanks for the help.....
fred75
Reply #12 on:
September 10, 2010, 11:58:38 pm »
I'd pressure test that cap... If the thermostat was stuck closed, you'd get a lot higher temp!!! Bad water pumps leak.
'82 C-10 305/TH350-TCC EDL PERF INT W/1406 AFB MSD-6A HDRS
Reply #13 on:
September 11, 2010, 12:24:57 am »
The bottom hose doesn’t see that much pressure the only problems it should have is if it collapses even if it did see high pressure the water pump will push water from one side of the block to the other and just bypass the hoses ex. when the stat is closed water is still being circulated in the block just not threw the rad. That’s why I think it just might have been lose. They don’t leak all the time just if the seal goes up if the blades wear down no leaks
fred75
Reply #14 on:
September 11, 2010, 01:54:02 am »
Good point on if blades wear down, no leaks.
Performance
