Author Topic: Little jobs get big fast  (Read 3361 times)
Offline Goobzilla
« on: October 06, 2010, 10:14:18 pm »
Don't you hate it when that happens?  I had a day off from work yesterday so I figured I'd bleed the brakes on the stepside since I had a spongy pedal.  Put the truck up on the lift and got out the Mity-Vac.  I actually thought ahead and sprayed penetrating fluid on all the bleeder screws since I knew it had been years since they were operated.  Got 3 open and of course snapped the 4th one off flush.  So I get to pull the wheel, drum and brake guts to get at the wheel cylinder.  At least a replacement is <10 bucks if I can't get this one drilled out.  I guess that's part of the fun of these old trucks, right?
Re: Little jobs get big fast
« Reply #1 on: October 06, 2010, 10:33:55 pm »
The blue wrench is your friend when it comes to bleeders!!!
« Reply #2 on: October 07, 2010, 01:20:39 am »
Might be worth it to replace the wheel cylinders anyways.
