Author Topic: pictures of where you mounted your gauages  (Read 6752 times)
Offline can am
« on: October 18, 2010, 07:57:58 pm »
I JUST BOUGHT A SET OF THREE GAUAGES. I cant seem to find a spot to mount them/ looking for pics of where you guys mounted yours.
Offline screamin86
Re: pictures of where you mounted your gauages
« Reply #1 on: October 18, 2010, 08:02:19 pm »
I'm going to mount mine on the lip under where the ashtray is. Ill post a picture when I get home from work tonight. Mine isn't bolted up yet but it will give you a idea.
86 ta:lm7 hot cam boltons
« Reply #2 on: October 18, 2010, 08:14:39 pm »
In my 86 I put them about the same spot center of the hump. Most states your not supposed to mount anything on the dash. Del failed my buds blazer cause he had a small tachometer on the center of the dash
Offline screamin86
« Reply #3 on: October 18, 2010, 09:03:36 pm »
Wow I didn't know that about the dash thing!
« Reply #4 on: October 18, 2010, 09:47:49 pm »
What gauges are you mounting?
Offline can am
« Reply #5 on: October 19, 2010, 03:54:20 am »
they are volts, water, oil. I am just looking for a few ideas of where to mount.I was thinking just below the stero but dont know if they will be in the way there. o I was thinking by the asytray as well. But i like by nthe stero better. I dont have any of my interior in yet so its hard to tell  how it will look. thats why I was interested in some pic to try to get sn idea
Offline SUX2BU99
« Reply #6 on: October 20, 2010, 05:18:30 pm »
If you don't have a/c, the pocket above the climate controls is a nice spot for 2 guages. I have my tach on my a-pillar.
Offline Grim 82
« Reply #7 on: October 20, 2010, 07:39:09 pm »
I also have my tach on the A-pillar. I have a trans temp gauge to mount somewhere also. Chris is working on pillar pods for our trucks, so I am just waiting to see what's available when that comes around. If you have the triple set with the bracket it should work to mount it on the bottom lip of the dash like screamin86 said.
« Reply #8 on: October 20, 2010, 09:07:40 pm »
Those are all gauges in the factory cluster. Why not mount them there?
