Author Topic: My truck won't shut off  (Read 4327 times)
Offline Retired MCPO
« on: October 27, 2010, 10:18:11 am »
I just replaced the ignition switch and the key switch assy and sometimes when I switch the key to off my 77 C-10 continues to run.  Not run on like a hot engine just runs like I didn't turn the key off.
Update, this afternoon I was running around and it shut off just fine then it did it again, I left the key in the off position and after idling for 30 seconds or so the truck shut off by itself.  Should I name it Christine?
Any suggestions?
« Last Edit: October 27, 2010, 02:39:30 pm by Retired MCPO »
Re: My truck won't shut off
« Reply #1 on: October 27, 2010, 06:10:07 pm »
Sounds like the ignition switch is not properly adjusted or it's sticking. Make sure it's located properly on the column and the rod is actuating fully.
Offline N2TRUX
« Reply #2 on: October 29, 2010, 10:13:51 am »
Welcome to the forum Retired MCPO.
« Reply #3 on: October 30, 2010, 05:13:28 pm »
    Welcome mcpo, from California.....
