Author Topic: Silly ford trans Q  (Read 4295 times)
Offline Layne
Silly ford trans Q
« on: November 07, 2010, 06:37:45 pm »
Just did a fluid and filter change in a 2000 Ford E150 with the 4.2 and the AOD maybe E? trans and When I pulled the pan, there was a yellow plastic thing that looks kinda like a lollipop. It was just hanging out in there... I think this was the first time the pan was pulled, and I dunno how long its been floating around. I couldn't find its home, so I pocketed it. Anybody know what it is, does or should be? I test drove it for 30 miles and its fine.... Should I be worried???
Offline Layne
Re: Silly ford trans Q
« Reply #1 on: November 07, 2010, 07:07:36 pm »
Upon further research, is this the plug installed from the factory that can be thrown away? If it is, On a side note, THAT'S DUMB OF THEM
Offline Layne
« Reply #3 on: November 08, 2010, 04:21:42 am »
Well they did circle the problem for ya ::)
« Reply #4 on: November 08, 2010, 05:38:50 pm »
We call it a cherry - and it used to mean you popped it when you pulled the pan and found it but too many jackasses put them back in the pan so don't believe that's what it means. It's sole purpose is to allow the trans to be shipped full then the dipstick just pushes it in to float around for eternity.
Offline Layne
« Reply #5 on: November 09, 2010, 12:00:12 am »
That's what I thought after some research. Thanks for the feed back. Kinda scary seeing that just floating around though.  Ford. enough said lol
