Author Topic: Building a truck for mileage, what would you do?  (Read 27101 times)
Offline 77c10diesel
« on: November 10, 2010, 02:24:30 pm »
I may be selling off my 2003 Cummins Dodge and need to get something to drive to work. I gave the 77 C10 Diesel to my son, and it will be done soon I hope.
So, other than going with another Diesel, how would be the best way to make a high MPG truck. I know there was a special optioned truck for 81-82 that had a 6cyl and a manual trans that got 30 MPG, but details seem hard to be find and verify.
I am thinking I would look for an 81-87 (best aerodynamics) with a manual trans. What transmissions were available? Any 5 speeds?
As for the engine, maybe a 305 with a very mild cam, dual plane manifold, 4 brl and some shorty headers?
Add an MSD and a K&N filter. Drop the truck a few inches and keep the tire size close to stock.
What would be a good rear ratio?
I know EFI would be the way to go, that might come latter, but what other suggestions would you have if starting from scratch to build for MPG?
I do not have the truck yet, so I can look for what I want, and around here they are plentiful and cheap. And, yes I know, 88+ are better for aerodynamics and FI, but they are ugly to me. It will be a daily driver 2wd, 1/2 ton mostly long back roads and freeway.
Thanks for any input you can give, or other posts on this subject, links, etc.
Scott
« Last Edit: November 10, 2010, 02:32:53 pm by 77c10diesel »
Re: Building a truck for mileage, what would you do?
« Reply #1 on: November 10, 2010, 05:32:03 pm »
350's would be the best IMO.  I firmly believe if the engine is geared right and is tuned you should be able to reach 20mpg.  A lot of folks call me a liar when I tell them I have gotten as high as 16 with my 3/4T 454.  If the engine isn't working hard to keep the truck going down the road that is what would yield the best results.  I had real good results in a 1972 C-10 using a 2 bbl which I had a variety of jets that I kept going down in size, kept checking the spark plugs and the tail pipe for color.  The truck had a TH350 and 3.08 rear gears running 235 75R 15's and got 16-17mpg.  The 72 was stock height and a lot heavier than a 81 or newer.  A rare optioned manual trans was a 4 speed OD and paired with a 2.73 rear end and 215 75R15's.  Of course the 305 was the V-8 of the 1/2 tons.  If I was going to build one I would have a 2.56 rear end and a 4 speed w/granny gear as opposed to an overdrive which is very hard to find.  My $.02
Offline three8six
« Reply #2 on: November 10, 2010, 05:40:34 pm »
Yea I seen an old article where they tested the 4.3 v6 out v. the 305 and the differences in mileage and power were very slight. I would say go with a 350.
Offline Stewart G Griffin
« Reply #3 on: November 10, 2010, 06:04:57 pm »
Believe it or not, as a first move, i would be looking to move down to say 195/75r 15's or even 195/65/60 r 15's and aluminum wheels.  Also, brand makes all the difference in the world;   i would be looking at Michelins.
Remember that these trucks weigh at least 3800 lbs and are large.  They simply are not high mpg vehicles.   The only way(s) to get more reasonable mpg is to go diesel, move down on cubes  (v-6 or inline) or go hi compression and water injection.
Pls see my ongoing scientific thread regarding mpg:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=8474.0
Offline Grim 82
« Reply #4 on: November 10, 2010, 06:14:56 pm »
Use a quadrajet on a V8, if you don't want TBI. I think the manual will win out for mileage in most any case except highway cruising, where the 700r4 with OD would keep the rpm's down some. I read somewhere that when they switched the front clip design in 81 it reduced something like 300 lbs from the vehicle. Travel light and keep it tuned up.
Offline 77c10diesel
« Reply #5 on: November 10, 2010, 06:24:25 pm »
I know that I will never see 30 MPG out of a full size Chevy/GMC truck. That is not what I am after. But, I also want to be able afford to drive it. Right now my 7000lb Dodge gets 20-21 MPG on Diesel. Diesel is about $.20-$.30 more per gallon, but it varies, sometimes its the same as gas. The problem is the added $380 payment on that beautiful truck. So, I can afford to use a little more fuel and still save some cash.
I am thinking I still need a 3/4 ton and may just go with a 6.2L Diesel, but I like the Idea of a second truck just for commuting, I hate little cars.
I swapped a 5.7L into my sons 77 just for fun, it was going to be mine, but he decided that he wanted it more than his 62 Corvair Monza.
Anyway, any more suggestions? I am open to all.
Offline 1980c10
« Reply #6 on: November 10, 2010, 06:50:39 pm »
I consistantly have gotten 18mpg never more or less city or hwy from my 82, LWB, 305, sm465, 4X4, q-jet with 31X10.5X15 bfg all terrain t/a's.
Only work I did was a tune up with a new complete dist. and spent a lot of time getting it to run just right(re-routing/replacing vacuum lines, timing etc).
With my '80 SWB, 250 I-6, sm465, 2WD, lowered 2/4, 275/60/15 firestones, I get 16-17 without as much power.
from that experience I would go for a 305 over a 250, I don't really really know why the 82 did so we'll on mpg. seems like I should have luck to see 15.
« Reply #7 on: November 10, 2010, 08:11:14 pm »
Diesel is going to yield the best mileage in any truck, close to 20mpg city (25mpg highway) is not out of the question with one.  I would get an 700R4 with it and gear it with 3.08 if all you are doing it driving.  If you want a manual, get a NV3500 out of a 88-up pickup.
81-87 truck got lighter because of several reasons, sheetmetal not being the biggest part, and it started in 1980.  Frame crossmembers were no longer solid, glass was thinner, power motors were smaller/lighter, brake rotors on the STD were thinner and had less drag among other things.
My high mileage 305 in my 87 pickup gets 22mpg on the highway and 17mpg in the city.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #8 on: November 10, 2010, 09:59:37 pm »
i never thought i'd say this since i love older vehicles (when I say older, I mean 60's and 70's) with points and carbs and no computers.  But since having my '91 3/4 ton 5.7  tbi sub 4x4, which, btw, gets me 17 mpg hwy (yes that's correct--w/33's on a 3.73 and 4l80E trans) and around 12 city, I am now sold on TBI engines over carbs. I have always been the one who likes to change and be able to adjust things (ie: idle), but, the reliability and eifficiency of a tbi is great.  So I'd be in the hunt for a '87+ truck which has tbi. And, I agree about the 5.7.  Never had a 305, but, to be a pick up truck, I can't see going smaller than a 350 so you won't have to keep your foot on the floor to move the heavy metal.
With that said, is your way to work mostly highway?  I have seen a few posts here say taller rear gear and OD etc...But, if you drive, say roughly 50% city or more, I would'nt opt for such a tall ratio drive line because, again, you'd have to keep your foot in the accelerator to get 'er going so often.  If it is mostly hwy miles, sure, go with the taller rear gear and OD.
Offline 77c10diesel
« Reply #9 on: November 11, 2010, 12:00:17 pm »
Right now my drive is 90% back roads, 45 MPH or higher, all straight roads, no curves and its about 20 miles. I may be changing jobs to a place about 1 hour away, but same kind of roads.
I do have another 5.7l diesel, but I think I would rather use a 6.2l or some other diesel (Isuzu, etc).
I think what I will end up with is 2 trucks. One will be a Crew Cab 3/4 ton with a 454 or diesel, the other will be my commuter. I need something to haul the 5th wheel, and kids, the other to just drive. I guess a Diesel crew cab might be able to do both if driven easy .
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #10 on: November 11, 2010, 12:39:29 pm »
Get an 81 or up shortbed truck, they're lighter and more aerodynamic than a comparable pre-81 truck.  Make sure you have the air dam on the front bumper.  keep a 28" or smaller tire, and keep them fairly skinny.  Also use the lightest duty suspension to save weight.  Barebones trucks weigh a good bit less than silverados with all the insulation, power options, AC and such.  Get an electric fan.  Nix the AC, maybe the power steering if you have arms like the hulks waist.  Lower the truck some.  Make sure all the body panels like up well.  If you have a V8 or diesel, maybe keep the AC, as I get better mileage with the windows up and the AC going than I do with the AC off and the windows down.  They don't wind-tunnel trucks with the windows and tailgates down.   ;D   Install a vacuum gauge in the dash <-That Really does help!  use aluminum wheels and light duty tires to save weight.  use a manual trans.   have a fleetside bed.  use a single tank setup so you aren't driving around with twice the fuel weight.  Get a cold air kit and hi flow air filter.  use full synthetic oil.   get smaller mirrors.   buy higher offset wheels like off of a newer truck, as the deep rally wheels are bad for air flow, as thats why all the new cars have no dish wheels on them.  get a trans with a lockup converter.  Open up the spark plug gaps approx. .010 from stock.  roller cam/rockers.  don't usehi volume oil pumps or water pumps.  benchseats weigh less than bucket seats.  dont dynomat anything.  use lightest GOOD grease you can in the wheel bearings.  use lightest weight GOOD oil you can in the differential.   MSD type ignition box- thats a big one.   Use resistor type spark plugs.  if you have overdrive, Keep a single exhaust system - 2.25" to 2.5"  with a chambered type muffler.
Offline Layne
« Reply #11 on: November 11, 2010, 11:36:06 pm »
Eat salads instead of Big Macs.... Lol I had to
Offline 77c10diesel
« Reply #12 on: November 12, 2010, 03:49:53 pm »
Good advice, the short wide 81+ trucks are not easy to come by, I have seen short step sides. May have to go with the salt flats/Rat Rod look with the salt flat disks narrow wheels and tires, lowered etc. That OK, I like that look anyway.
How hard is it to install a later 5 speed in an older truck?
Seems like it might be worth getting an 88+ parts truck to get the EFI and 5 speed out of.
Offline captain carnage
« Reply #13 on: November 23, 2010, 08:27:26 pm »
I got between 24-25 mpg with this setup, and its no word of a lie, no one ever believes me until they come for a ride with me and see for themselves. I bought this truck as a DD while I fixed up my 4x4 and its still my DD 3 years later. Its an 84 1/2 ton longbox. It has a 305 (stock as far as I know), with a 700R4, and a 3.07 posi rearend. 235/75/15 tires on factory rally rims. Almost all of the factory emissions crap is still on the motor, and it has a quadrajet on it. All I ever did to it was routine maintenance. Unfortunately its lacking a little these days as I've put MANY miles on it and it could use some love. But it still gets around 20 mpg or so. As for the power it has lots, no need for a 350, when properly tuned and in good shape these engines in these lighter trucks are great.
« Reply #14 on: November 24, 2010, 09:42:48 pm »
1) Is this the LE9 engine?
2) Cancel my previous comments;  i now feel the best way is to look for a diesel pickup(even though you said other than diesel.....)
