Author Topic: Carb question  (Read 24804 times)
Offline 1979C20
  • Kyle Taulton.
Carb question
« on: December 12, 2010, 03:31:14 pm »
Would a Holley 750cfm double pumper part#r84013 be too much for a basically stock 350 with a 440 292 comp cam? Stock heads, stock crank, stock pistons, stock intake, stock distributor, headers, about 2000mi on engine. Daily driven, like its a race car. Haha. I only get about 8 or 9mpg with my stock qjet that needs replaced/rebuilt. So I dont expect much mileage.
Re: Carb question
« Reply #1 on: December 12, 2010, 11:04:37 pm »
Yes.
Offline 1979C20
  • Kyle Taulton.
Re: Carb question
« Reply #2 on: December 13, 2010, 01:00:10 am »
Really? I searched online and was told the stock rochester q-jet was a 750-800cfm....
Re: Carb question
« Reply #3 on: December 13, 2010, 04:14:14 am »
The quad can be tuned on to run that much. A Holley you want no more than 650 with a stock engine. You will find if you want better gas mpg than your gearing should be lower than it is and drive it like an old man
Offline Grim 82
Re: Carb question
« Reply #4 on: December 13, 2010, 09:23:11 am »
To save money and get better mileage rebuild the q-jet. If you just want a shiny new carb a 600 cfm Edelbrock or Holley would be plenty for a stock 350. You would need the adapter plate to put it on your stock manifold if you buy a square bore carb.
Re: Carb question
« Reply #5 on: December 13, 2010, 11:31:05 am »
Q-jet is MAX Flow of 750-800cfm.  It runs on 2 small primaries for the most part and the secondaries work on Vacuum demand, generically speaking the motor will only pull what it needs.
A double pumper has a mechanical secondary and when it is engaged it will dump the fuel in regardless if it needs it or not.
Offline 1979C20
  • Kyle Taulton.
Re: Carb question
« Reply #6 on: December 13, 2010, 02:16:23 pm »
How do you bolt the adapter plate on? My dad had on in the shed out back, mr. Gasket square to spread. It has 4 2sided studs, 4 nuts, and 4 washers.
Re: Carb question
« Reply #7 on: December 13, 2010, 03:13:35 pm »
Bolt it to the intake then bolt the Carb on
Offline 1979C20
  • Kyle Taulton.
Re: Carb question
« Reply #8 on: December 13, 2010, 04:05:26 pm »
But how? I dont understand how it would bolt on.
Offline Grim 82
Re: Carb question
« Reply #9 on: December 13, 2010, 04:12:52 pm »
There should be recessed holes to bolt it to the intake, then 4 studs that thread into the adapter, then put the carb on the studs and put nuts on them.
Offline 1979C20
  • Kyle Taulton.
Re: Carb question
« Reply #10 on: December 13, 2010, 04:19:20 pm »
Anybody have pictures of how to install one? Because there are several holes and what now. Like I said, I have 4 2 sided studs, one side is course thread that I believe threads into the intake manifold, and the other side is fine thread which matches the 4 nuts.
Offline Grim 82
Re: Carb question
« Reply #11 on: December 13, 2010, 04:28:37 pm »
And you need 4 bolts to bolt the adapter to the intake. The fine thread end of the studs thread into the adapter. Make sure you use 2 gaskets.
Offline Grim 82
Offline 1979C20
  • Kyle Taulton.
Re: Carb question
« Reply #13 on: December 13, 2010, 05:22:35 pm »
There are no threaded holes on the adapter plate. how does it bolt to the intake and carb? nuts on either side of the plate?
Offline Grim 82
Re: Carb question
« Reply #14 on: December 13, 2010, 06:03:03 pm »
Lets see a pic of the adapter.
