Performance
Carb question
Topic: Carb question (Read 24801 times)
Re: Carb question
Reply #15 on:
December 13, 2010, 06:05:16 pm »
Did you check out the link Grim 82 posted? shouldered allen bolts on the adapter to the intake, studs from the adapter to the carb.
1979C20
Kyle Taulton.
Re: Carb question
Reply #16 on:
December 13, 2010, 11:37:15 pm »
I'm on my phone, so I cannot upload a pic of mine, but I found a retail pic of it. [url]http://www.jegs.com/images/photos/700/720/720-1932.jpg[url/] on this side of the plate, the hex holes are on the outsides, but on the reversed side of the plat the hex holes are on the insides. I only have 4 equal length 2 sided studs, 4 nuts, and 4 washers
1979C20
Kyle Taulton.
Re: Carb question
Reply #17 on:
December 13, 2010, 11:49:09 pm »
Last Edit: December 14, 2010, 04:35:08 pm by Captkaos
Re: Carb question
Reply #18 on:
December 14, 2010, 04:31:46 am »
Re: Carb question
Reply #19 on:
December 14, 2010, 04:39:58 am »
ok you put the silver bolts threw the bottom facing up, then you set the gaskets on now the trick part is to keep all the bolts in place while its sitting over the intake don’t drop any bolts down then you take the black bolts "Allen/hex" key if I can remember right and tighten the adapter plate to the intake, then you set the carb onto the adapter plate and use the nuts to hold it down. As far as the studs I don’t think you use them with your application
Re: Carb question
Reply #20 on:
December 14, 2010, 04:44:19 am »
Your pic was close to the code just move the backspace over in front of the img /img
1979C20
Kyle Taulton.
Re: Carb question
Reply #21 on:
December 14, 2010, 04:25:23 pm »
Thanks Irish, for the advice on the img posting and the help with the plate. Thanks everyone else too. Sadly, the guy on craigslist flaked out on me like a loser and didnt call or answer his phone. So I'm stuck with my qjet. My dad said he would rebuild it for me. So, new question! How do you rebuild a qjet? Like, what do you need. Obviously a rebuild kit. 45 bucks at orielly's. What else? Can or two of carb cleaner? Vat of carb cleaner? Any instructions on how do disassemble and reassemble a Rochester q-jet carb from a 79 c20 with a 350?
Re: Carb question
Reply #22 on:
December 14, 2010, 07:47:03 pm »
A good tip buy a book on the quads wish I could help but they are at the parts store. Its not that hard and one of those shows on power block rebuilt one I'm sure it was Ian
1979C20
Kyle Taulton.
Re: Carb question
Reply #23 on:
December 14, 2010, 08:54:44 pm »
Okay! New new question. My dad has a holley carb out back that is in really good condition that isn't being used because it is dumping fuel into the venturis. He says it isn't the needle and seat and that the bowl is not overflowing. He says it is dripping out of the power valves. I do believe it was rebuilt not too long ago. So, what would this be? What would cause a carb to leak out of the power val
ves?
TexasRed
Re: Carb question
Reply #24 on:
December 14, 2010, 09:02:58 pm »
a blown power valve would dump fuel
Re: Carb question
Reply #25 on:
December 15, 2010, 12:19:49 am »
does it dump after the engine is shut off?
1979C20
Kyle Taulton.
Re: Carb question
Reply #26 on:
December 15, 2010, 01:03:22 am »
It dumps ALL of the time. At idle right after start up. It just drips out of the booster valves in the primaries. Would it really be the power valve in a rebuilt carb?
HAULIN IT
Re: Carb question
Reply #27 on:
December 15, 2010, 03:00:09 am »
A bit off of the real topic, but I'm going to mention a few things based on reading your original post. For starters, it is a real shame that guys abandon the Q-jet carb on so many projects...the ones they are ideal for seem to be the ones they get tossed off of most. That being said, a properly tuned Q-jet will work very well for what your doing. Also you don't end up with "rigged": fuel hose, carb linkage, air cleaner, choke system, ect. ect. like so many people do when ditching the stock carb.
Now to the other things. I'm not sure what cam you have based on your "440 292" numbers. The .440 would be lift, which they show a .440 lift cam in there "High Energy" line with an advertised duration of 260. The 292 you mentioned is the advertised duration...Comp has one of those, but with a .501 lift. If you really have the first cam, that should work well with your mostly stock engine, however if you really have the 292...it should be removed, it will be killing the little bit of performace & efficiency your engine could have.
If you do have the "High Energy" cam, a nicely tuned Q-jet should make for a fairly good runner with reasonable manners & mileage. My Two Cents. Lorne
1979C20
Kyle Taulton.
Re: Carb question
Reply #28 on:
December 15, 2010, 02:37:29 pm »
I just went and read the specs card from comp cams, you are correct. It is 260 duration. I can grab the part number in a bit. The reason I'm 'abandoning' the qjet is because it a pain to rebuild. I'm looking for something in good condition I can just throw on and tune to my truck.
ToddN
Re: Carb question
Reply #29 on:
December 17, 2010, 08:16:24 pm »
I second the thumbs up for the Q-Jet. If you are running the vehicle at the strip and you need to take the carb off every other run to do adjustments then get a Holley or an Edel. If you want to hop in your truck in the morning and stomp on it to get to work on time then stick with the Qjet. The Rochester Q jet is PLENTY of carb for a stock 350. In fact...I just pulled off an Edelbrock 1407 600cfm and put an electric choke coil on an old Q jet and it runs twice as good. This Q jet was also sitting on a rusted out delivery van and with two pumps on the pedal, it fired right up and I haven't looked back since.
A government big enough to give you everything you need, is a government big enough to take everything you have.
Performance
Carb question
