4 Wheel Drives
2wd to 4wd conversion
Topic: 2wd to 4wd conversion (Read 55015 times)
thirsty
Re: 2wd to 4wd conversion
Reply #15 on:
December 15, 2010, 07:47:09 am »
I would buy a whole 3/4 ton parts truck so that you have the 4wd spring hangers and measurements to put the axle in. You would also get driveshafts, t-case, tranny, crossmember.
Build thread
1979C20
Kyle Taulton.
Reply #16 on:
December 15, 2010, 02:53:24 pm »
Well, I haven't found any 3/4ton D44s. Right now, I'm just looking to mount the front axle with brakes so it is driveable. I have a 2wd transmission so I need to find a divorced transfer case or a new tranny. The front axle is just my first step towards converting my beasty.
Reply #17 on:
December 16, 2010, 10:23:02 am »
You need the shackles odor the front two choice a buy new. Don't know the price but seen some for 50 apiece or b. Buy a used truck where not only will you have shackles but like said transfer case transmission and drive shaft
1979C20
Kyle Taulton.
Reply #18 on:
December 16, 2010, 11:16:08 am »
I cant find a reasonably priced 3/4 ton 4x4 anywhere, and I don't have a lot of money to spend. If I had a lot of money, I would buy a 4wheel drive and turn my truck into a donor!
1979C20
Kyle Taulton.
Reply #19 on:
December 16, 2010, 11:23:23 am »
Hmmmm. If I found a 4x4 in the junk yard, How could I remove the spring hangers and what not? How do you guys remover the rivets from the trucks at the yard?
756man
Reply #20 on:
December 16, 2010, 05:18:14 pm »
Cutting torch ! Then reinstall with grade 8 bolts.
1985 Chevy K-20 longstepside, 350,Turbo 400
1979C20
Kyle Taulton.
Reply #21 on:
December 16, 2010, 06:53:26 pm »
But...... How the heck do you take a cutting torch to pick a part?
Da67goatman
Site Supporters
Burban
Reply #22 on:
December 16, 2010, 07:05:18 pm »
On a golf cart.
<Pitcrew>
1992 fullsize Blazer 4x4 35s no lift, 4.10s, Hella driving lights, TJ Flares, Huge bumpers, Snorkel, custom interior
1979C20
Kyle Taulton.
Reply #23 on:
December 16, 2010, 07:07:40 pm »
Hahahaha. Okay, what about not having a cutting torch? What would you use?
hotrod24
Reply #24 on:
December 16, 2010, 07:11:10 pm »
You can also do the X if you like with a grinder or a cut off tool and then take a air hammer and hammer out the rivets, But a torch is the bast way to do it...
Last Edit: December 16, 2010, 07:48:08 pm by hotrod24
1978 pontiac grand prix...
Da67goatman
Site Supporters
Burban
Reply #25 on:
December 16, 2010, 07:45:32 pm »
I take a battery powered sawzall and just take the section of frame too and take the rivets out at home.
<Pitcrew>
756man
Reply #26 on:
December 16, 2010, 10:35:24 pm »
1979C20, if you don't have a torch you probably shouldn't be working on your own truck, much less trying to convert it to 4 wd.
Da67goatman
Site Supporters
Burban
Reply #27 on:
December 16, 2010, 10:43:27 pm »
That's not true, I do not own a torch or plasma and have rebuilt mine from ground up. Those would make it easier, but are not essential.
<Pitcrew>
1979C20
Kyle Taulton.
Reply #28 on:
December 16, 2010, 11:51:38 pm »
My dad has an oxyacetylene and a plasma torch and 2 welders. I personally do not have a torch to take to pick a part.
thirsty
Reply #29 on:
December 17, 2010, 08:29:39 am »
Bring the whole chassis home from the boneyard. I cut the heads off the rivets with a torch then used a air chisel with a punch to pound them out. You can grind the head off with a 4" grinder them use a hammer and punch also. My opinion is that you will need to have a 4x4 frame to find the exact locations of where to mount your 4wd brackets.
Build thread
4 Wheel Drives
