Author Topic: My '84 Street/Strip stepside  (Read 62094 times)
Offline GUITAR1989
Re: My '84 Street/Strip stepside
« Reply #15 on: January 05, 2011, 04:41:52 am »
Man that truck is slick 8)
Offline 75ChevyGuy
« Reply #16 on: January 19, 2011, 01:44:33 pm »
What did you use to make that center console? That thing looks slick!
Offline acefoxx
  • 84 SierraClassic stepside/85 K5 Blazer
    • Acefoxx.com
« Reply #17 on: January 20, 2011, 04:14:56 pm »
I made the box itself out of MDF 1/2 and 3/4 in. I covered the inlay with vinyl. I painted the box with Lowes brand textured spray paint close to the color of my interior. I then sprayed over that with Lowes brand spray paint that matched the interior perfectly. I made the template in the truck with some cardboard then just jigsawed it out on the MDF. Few brad nails from my little nail gun and then the paint. The top of the box for the arm rest/compartment was some foam cushion from the fabric store covered in the same vinyl I did the dash and inlay with.
'84 GMC SierraClassic/'85 K5 Blazer Silverado
http://acefoxx.com
Offline acefoxx
    • Acefoxx.com
« Reply #18 on: January 21, 2011, 05:36:14 pm »
Well I ordered my one piece windows kit and the flush mount back window today. Can't wait to get them in. I had a technical difficulty last week when I was testing driving old blue with the new PowerJection III system freshly installed. Turns out I am not that great a welder. The 4 link to frame bracket popped right off with my new found responsiveness from the fuel injection system. LOL Few cargo straps and I pulled the rear end back in place and drover her home. I'll get her fixed tomorrow morning for another test drive.
http://acefoxx.com
« Reply #19 on: January 21, 2011, 07:11:26 pm »
why didn't you order them from me?  Could have save you a couple bucks.
Offline GUITAR1989
« Reply #20 on: January 22, 2011, 02:20:24 am »
Hey man :) Hows that Powerjection III working out for you? It looks like a cool little gadget. Was it really as easy to install as the Company makes it seam?
Offline acefoxx
    • Acefoxx.com
« Reply #21 on: January 22, 2011, 04:55:36 pm »
Well installation had its pitfalls. First off I had to redo my fuel lines a bit. My old fuel pump was forward on the frame. I had to cut and reinstall the braided -an fittings so I could mount the high pressure pump closer to the tank. That took me most of the first day. Wiring seemed easy enough. Battery, switch, tach and it has it's own built in fuel pump relay so it had a wire for the fuel pump power also. Installed the O2 sensor bung, the strap on type. I'll weld it when I upgrade my exhaust later. And lastly the temp sender in the intake manifold. I then had to install a return line to my fuel cell. I just used some fuel quality rubber line for that. Now for the problems:
1. The O2 bung was missing the gasket that was advertised with the kit.
2. When I barely started bolting down the throttle body itself the corner cracked. Yes the half inch thick billet bolt flange cracked. It didn't crack all the way through so I pressed on just to hear it start.
3. I turn the key for the first time and the fuel pump comes on for all of half a second. DOA.
At that point I had about 9 hours into the job and went to bed. I got up the next morning and in less then 30 mins I had it all packed up and back in the box. After a 3 hour round trip run to Summit Racing I was back at the house and in less then an hour I had the kit installed again. The second kit had inspection sheets in the box that showed someone did a QA on it before sending it out. The first kit didn't have that.
So it took several tries and I still couldn't get the thing to start. I turned the key and waited for the fuel injectors to squirt. Then I tried to turn it over. It would kick over for a second and then die. This went on for an hour. I finally called the Tech support(very helpful and friendly guys btw). After him hearing what it sounded like trying to start over the phone he deduced that the problem was my source for the switch wire was being interrupted during cranking. I had used the choke wire. He instructed me to move it to the pos side of the coil. After that it started right up.
I am still having problems with cold starts. I have to find time to get out there with Tech support and adjust(with the laptop) the IAC valve and the idle itself and the richness on cold start settings.
But on a final note. It runs like a scalded cat down the roads. So much so that I popped the weld on my four link and almost lost my rear end down the road. A few cargo straps and I drove it back home and drilled and bolted it back together.
http://acefoxx.com
Offline GUITAR1989
« Reply #22 on: January 22, 2011, 10:39:45 pm »
Dang that sounds like a horror story. Hope the 2nd one works out for you :) Hey man im thinking about painting my chassis and engine bay. what did u use on yours? It looks really nice.
Offline acefoxx
    • Acefoxx.com
« Reply #23 on: January 23, 2011, 06:54:02 am »
I used a little bondo to fill in some of the unused holes in the fire wall. Then I just painted it just like I did with the rest of the body. I used Nasons paint. It is made by Dupont I believe. I used professional grade simi gloss rustolium for the frame.
Sent from my DROIDX using Tapatalk
http://acefoxx.com
Offline 3rtr
« Reply #24 on: January 27, 2011, 04:36:08 pm »
Where did u get the Glass' hood ? Ive been searching for a company that still makes fiberglass hoods for theese trucks with no luck ... Do u know if they make the older style hood out of glass too ?? Thanks ... let me know
Offline acefoxx
    • Acefoxx.com
« Reply #25 on: January 27, 2011, 06:28:22 pm »
I sent you a PM on it cause I don't quite understand what vendors I can list out loud and which ones I can't?
http://acefoxx.com
« Reply #26 on: January 27, 2011, 06:45:35 pm »
I have a 73-80 fiberglass cowl hood and can't give the thing away. I would go with a steel all day long.
http://www.up22.com/chevytruck.htm#1973 - 80 Chevy Truck
http://www.usbody.com/
Chris probably has sources too
Offline drag80
« Reply #27 on: January 27, 2011, 09:54:55 pm »
harwood fiberglass as well, they make nice stuff
Offline acefoxx
    • Acefoxx.com
« Reply #28 on: January 28, 2011, 08:40:56 pm »
Well I finally got a starter that doesn't drag, grind, whine, or chatter. I didn't even have to put in any shims. Almost 10 years with this truck and that has never happened.
Anyhow. I am finally starting to see some progress with the Powerjection III unit. Tech guy told me to plug my IAC valve hole and adjust the butterflies till it will idle then unplug the IAC. I am to do this cold before the adaptive learning kicks in at 150 deg temp. I did this and it starts right up now. Tomorrow I'll change out the thermostat to a more appropriate temp(165 deg is way to low for this motor) and then I'll plug laptop in and play with the computer settings a little bit.
http://acefoxx.com
Offline slammed79
  • Thou shalt not drive stock
« Reply #29 on: January 29, 2011, 12:58:35 am »
I wonder how bad the shipping would be, I'd take it off yer hands Vile!
Praise the lowered
