Author Topic: Fix NP208 leak w/o dropping it?  (Read 4018 times)
Offline mick1775
« on: December 22, 2010, 03:34:13 pm »
Hoping to pick someone's brain here. I have small leak on my t-case, narrowed it down to where the two halves mate up. From what I've gathered there's just RTV on the surfaces. Is it possible to pull off the rear cover and replace the sealant with out dropping the whole thing?
Offline Grim 82
Re: Fix NP208 leak w/o dropping it?
« Reply #1 on: December 22, 2010, 03:38:22 pm »
It may be possible, but I would pull it and put it front down on a bench to reseal it.
Offline Psycho71
« Reply #2 on: December 22, 2010, 06:29:26 pm »
I just re-sealed  and inspected the 208 on my burb. While I have no experience actually servicing one while installed, I can almost assuredly say that it will be a PIA to split the case and re-assemble while it's in the truck. It was a bit tricky to get the shafts to seat while making sure the selector fork spring was going in at the same time while I had mine out and upright on the bench. I could see lots of cussing going on if had I attempted that while it was installed.
I say pull it out and do it on the bench.
Offline thirsty
    • Suitor's Garage
« Reply #3 on: December 23, 2010, 07:22:55 am »
Removal and installation will take less time than the actual splitting it,inspecting it, cleaning the surfaces, and putting it back together. I would pull it for sure.
