Author Topic: Door Slam  (Read 30046 times)
Offline Thermal Izod
Re: Door Slam
« Reply #15 on: December 28, 2010, 08:33:24 am »
1982, what size pex did you use for this?
1982 Shortbed K10 Silverado.  305 ci with a mild cam, full true dual exhaust (Long tube headers, "H" pipe, and Thrush Turbo mufflers.  4x4, and otherwise completely stock.  about 153,000 miles.
Offline Edahall
Re: Door Slam
« Reply #16 on: December 28, 2010, 09:19:41 am »
Use 1/2" pex.  It should look like this when finished.
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
Re: Door Slam
« Reply #17 on: December 28, 2010, 09:22:27 am »
did you use some kind of adheasive, or just cut and place it on?
Offline Edahall
Re: Door Slam
« Reply #18 on: December 28, 2010, 02:54:58 pm »
did you use some kind of adhesive, or just cut and place it on?
1982 mentioned using Pex so I got curious and did a search on it.  That said, I checked my 1990 Suburban and none of the strikers had the bushings.  The doors don't shut too bad for a truck but it'll be interesting how they close after adding the bushings.  Never know, maybe the doors will shut nice like my Italian Allante.   Regarding adhesive, I would definitely use some type of adhesive.  The type I have in mind is PL Polyurethane Premium Construction Adhesive.  It's super strong and has a thick consistency so it doesn't run once applied.
-3.73 gears
-2" Lift
Offline 1982 Daily Driver
Re: Door Slam
« Reply #19 on: December 28, 2010, 03:18:17 pm »
The half inch pex fits pretty tight I didn't use any adhesive, and it only cost about $1.30 for 4 feet of it at the hardware store.
Re: Door Slam
« Reply #20 on: December 28, 2010, 03:25:42 pm »
awesome...I'll stop by Lowe's on my way home tonight.  Thanks.
Re: Door Slam
« Reply #21 on: December 29, 2010, 10:19:13 am »
The bushing should roll on the striker bolt so do not use adhesive. Strikers are cheap and the actual direct replacement bushing is cheaper.
Offline ctl_dog
Re: Door Slam
« Reply #22 on: December 30, 2010, 10:10:28 am »
I used the pex trick, made a huge difference.
Re: Door Slam
« Reply #23 on: December 31, 2010, 10:30:44 am »
Ok, so this morning I spent about 10 minutes doing the pex trick on both doors....Wow, what a difference.  That certainly fixed the problem.  I also noticed that the doors click open smoother, both inside and out.  With the doors open about 4-6", I am now able to push them all the way shut with just the tip of my finger...Tremendous.  No more loud door slam, they shut as easy and quiet as a brand new car.
Thanks for the tip to all who posted on this.  $2.00, ten minutes, and one tool used is the biggest bang for the buck/time job I have done as far back as I can remember.
Re: Door Slam
« Reply #24 on: December 31, 2010, 05:12:08 pm »
Do you take any material out or just make a slice to get it to fit on?
Re: Door Slam
« Reply #25 on: December 31, 2010, 05:15:14 pm »
I just cut them to size, then used tin snips to slice a line down them longways....then simply wrestle them on, and wa-la!
Offline velojym
Re: Door Slam
« Reply #26 on: December 31, 2010, 06:02:49 pm »
A PO of my truck used tape... didn't work so well. I'll either try a new bolt or the pex trick, myself.
Re: Door Slam
« Reply #27 on: December 31, 2010, 06:12:43 pm »
Thanks Thermal. I have a hack saw, so it should be easy.
Pex, aka PVC?
Re: Door Slam
« Reply #28 on: December 31, 2010, 06:16:45 pm »
No problem....I hack sawed it to size, then sliced with tin snips...easy easy
Offline Grim 82
Re: Door Slam
« Reply #29 on: December 31, 2010, 06:17:40 pm »
Pex, aka PVC?
No, specify PEX. You'll never get rigid PVC over the bolt.
