Author Topic: lowering gear ratio  (Read 18375 times)
Offline C-Moore502
lowering gear ratio
« on: January 15, 2011, 01:48:26 pm »
So I have a 84 K20 with the 6.2 and my truck has the 3.73 gear ratio. I think I would like to lower it to 4.10. I'm still a little new to 4x4's so any input would be greatly appreciated. If I do change the gearing which parts besides the axles and transfer case would need to be re-geared as well?
84' K20 6.2L "The Duke"
Offline Da67goatman
  • Burban
Re: lowering gear ratio
« Reply #1 on: January 15, 2011, 02:20:51 pm »
I think you should be fine unless your running some 35" or larger tires.
<Pitcrew>
Offline C-Moore502
« Reply #2 on: January 16, 2011, 09:52:17 am »
Well I was considering getting some 35's and a 6" lift kit but I'm still trying to figure it all out.
Offline motion427
« Reply #3 on: January 16, 2011, 12:52:45 pm »
Just need to regear the differentials,not the transfer case.
86 K10,350 Roller Cam,T350,NP205,10 bolt posi,12 bolt posi,33" tires.
85 K30,454,T400,NP205,Dana 60,14 bolt,being built now.
04 Avalanche Z71,6.0L,TVS 1900,Dynatech,Corsa,etc...
06 TBSS,AWD,6.0L,Kooks,C6 fan kit,etc...
75 Nova SS,502,T350,12 bolt
« Reply #4 on: January 16, 2011, 04:15:28 pm »
I think you will be good with 3.73. I'm running 4.10 with a sm465 and 38s. So it has a 1.1 transmission ratio and at 50 she's at 2k. That's high in my opinion I would like to step up once I get a chance
Offline C-Moore502
« Reply #5 on: January 16, 2011, 06:01:40 pm »
Alrighty then, well thanks for saving me some time and money then guys
Offline dcayers
« Reply #6 on: March 19, 2011, 11:56:28 pm »
You can expect to lose some fuel mileage until you put the bigger tires on it. We just pull the 4.10's out of the 84 6.2 and put 3.42 in and helped the fuel mileage tremendously. Diesel's like lower rpm range.
1986 K5 3/4 350 tbi 700r4 6inch susp. and 3inch body 41x14.50x20
2005 Dodge Neon SRT-4 Stage 1
Offline 1979C20
  • Kyle Taulton.
« Reply #7 on: March 20, 2011, 06:10:48 am »
irish, my trucks got the sm465, 4.10's or 4.11's and 30" tires and it runs 2k rpms at 45! 50 is closer to 2200rpms.
« Reply #8 on: March 20, 2011, 10:53:24 am »
Lol thought I had it bad
I made a little boo boo ment 55 was 50 with the 4.56
« Last Edit: March 20, 2011, 11:01:40 am by Irish_Alley »
Offline 4x4x4x
  • 85k10 diesel
« Reply #9 on: March 21, 2011, 03:28:01 pm »
we have a 1985 k10 with a 6.5 turbo diesel and 700r4. it had 373's, when we replaced the tires with 33/1250r15 goodyear mtr's the gearing was too high, it was hard to pull hills (shifting between 3rd and 4th gear) and the truck lacked power. we switched out the front and rear differential gears (and added electric lockers) and now the truck runs great. i checked the speedo with a gps and it reflects the correct speed, and the engine rpm is back in the stock range. the last time i checked mpg is was 22mpg hwy (driving easy)
randy's ring & pinion site has rpm calculators that will allow you to compair engine rpm/tire size/differential gear ratio.
http://www.ringpinion.com/Calc_RPM.aspx
alec
85 k10 swb, 6.5 diesel. banks sidewinder turbo, 700r4, auburn gear ected limited slip/lockers f & r, 411 gears, front slotted disks, rear disk brakes, 4"exhaust,  cibie headlight and fog lights, rancho rear spring lift, rancho shocks, new ft. springs,
« Reply #10 on: March 22, 2011, 11:08:20 pm »
alec
      Which gears did you switch too ?  4.11 s.
Offline 4x4x4x
  • 85k10 diesel
« Reply #11 on: April 14, 2011, 06:56:26 pm »
we went with 411's, also added auburn gear ected limited slip/electic lockers and rear disk brakes. just had marine injectors installed, big difference in power.
« Reply #12 on: April 14, 2011, 07:34:04 pm »
im running 33 tires and 3.73 gears and I dont have a problem with it.
Offline 1979C20
  • Kyle Taulton.
« Reply #13 on: April 14, 2011, 07:50:31 pm »
My mom has 3.73s and 35's on her 03 avalanche andbits doin a bit of a number on her engine
« Reply #14 on: April 14, 2011, 07:54:23 pm »
key word: 2003
Our trucks can handle more than a newer IFS truck
