Author Topic: Why would i even think of changing to posi?  (Read 4269 times)
Offline Zeked
« on: January 16, 2011, 10:34:05 pm »
I have a 87 short step and Im " in there " .....   why should I consider a posi if this is a ranch truck,  but goes to the  cowboy bar in town by itself?
zeke duge
Often Wrong......Never in Doubt!
Re: Why would i even think of changing to posi?
« Reply #1 on: January 17, 2011, 03:51:41 am »
posi are more if you go mudding or go into the mud on the ranch most time you dont even need it just one of those things that helps out if you have a load on or something
« Reply #2 on: January 17, 2011, 07:05:46 am »
     I don't believe from your description of what you do with your truck that you need a posi.  In fact I would bet if you put one in you would hate it and take it right back out.
Offline jackjeckel757
« Reply #3 on: January 17, 2011, 08:46:53 am »
If you don't know how to react to posi, your truck will go sideways when you give it too much gas on a slippery surface, a regular slip diff with only 1 wheel spinning doesn't do this and can be easier to control.
Offline three8six
« Reply #4 on: January 17, 2011, 09:22:59 am »
I wouldn't posi you truck unless your ranch has some real rough terrain.
