Author Topic: I feel like a dummy  (Read 9074 times)
Offline BigBlueBoy
I feel like a dummy
« on: January 17, 2011, 05:53:28 pm »
Okay so today while I was out shoveling I seem to have lost my keys and like an idiot I never made the spares i was going to make. So the question here is whats the best way to replace the ignition without the key? I know my 87 F150 I had, had a pin I drilled out when it broke since it wouldn't turn. Is there a pin like that in a 85 Suburban??
Drive it like you stole it!!
Re: I feel like a dummy
« Reply #1 on: January 17, 2011, 06:37:07 pm »
It depends on what style you have could be a screw that holds it in or you have to break part of the column off either way you need to take the steering wheel off
Offline 1980c10
« Reply #3 on: January 17, 2011, 07:03:43 pm »
You can have a key made by a lock shop that will work not too sure of the cost but it's might be worth checking out.
Offline slammed79
  • Thou shalt not drive stock
« Reply #4 on: January 17, 2011, 10:39:42 pm »
Its cheaper to get into the column and swap the switch. A new one with two keys will run about $20 @ most chain stores. I've done it enough times now that I'm in and out in about 25 min.
Praise the lowered
Offline BigBlueBoy
« Reply #5 on: January 21, 2011, 05:58:39 pm »
http://www.youtube.com/watch?v=_L_85UkLOu8
This link is great for those needing to remove their lock cylinder for your ignition. Was very easy and I got it done in no time. Thanks everyone for your help.
