Author Topic: will it drop?  (Read 5603 times)
Offline Big cheese
will it drop?
« on: January 28, 2011, 08:50:48 pm »
was wondering i want to drop my truck with 3 inch spindels and 2inch drop coils in front and flip kit in rear The question is will i have problems with these rims and tires they are fifteens and the tire are 31x10.5 if not can i just get a smaller tire
87 gmc by Big cheeser, on Flickr
Offline 1980c10
Re: will it drop?
« Reply #1 on: January 28, 2011, 09:41:29 pm »
rims are fine, tires may be too big. You would probably want smaller tires anyway just to make it look right.
Offline N2TRUX
Re: will it drop?
« Reply #2 on: January 29, 2011, 01:03:20 pm »
Tires are way too tall. The rims will work, but you are going to have to do some grinding on the front A-arm for them to clear with a 3" spindle.
If your wanting to go lower, I suggest selling the tires and wheels and get a set that are more in tune with the look of a lowered truck.
Offline Da67goatman
  • Burban
Re: will it drop?
« Reply #3 on: January 29, 2011, 01:10:37 pm »
They would look great tucked up into the wheel wells with a solid 3/5 drop.  Might have clearance issues with the fronts when turning, but that's why its a shortie, so you don't have to turn as hard due to smaller turning radius.
<Pitcrew>
Offline Big cheese
Re: will it drop?
« Reply #4 on: January 30, 2011, 02:48:25 pm »
Im still not to confident in grinding my lower control arm just dont feel comfortable even though ive seen many her do it so my question is .With 3 inch spindles what is the smallest rim i can go with out any clearance issues just bolt on and look good i had thoughts about putting twentys but what is holding me back is i still want a tire with a little bit of sidewall thanks again you guys are great thanks again
Offline three8six
Re: will it drop?
« Reply #5 on: January 30, 2011, 03:58:57 pm »
@Big Cheese some will tell you 17's but it has more to do with the backspacing. I have 17s and they just sit in the garage because they hit and because the guy who powdercoated them did the worst job Ive ever seen. I endedup ordering spacers so I could run spindles on my stock 15's.
Offline Big cheese
Re: will it drop?
« Reply #6 on: January 30, 2011, 07:35:50 pm »
@three8six how much of a spacer did you put to clear the stock fifteens and with the spacers did the wheels tuck under the front fender and what backspacing did u have on those 17s sittin in the garage i really dont want that tohappen to me its got to bother seeing those rims just sittin there in the garage thanks
Offline three8six
Re: will it drop?
« Reply #7 on: January 31, 2011, 10:08:39 am »
5.06 inch of backspacing(stock impala SS wheels). If you had a set with 4.25 BS I would think they would work. I used one inch spacers on 15x7's really ideally, Ideally I would of used 1.5 inch spacers with the factory 15x6.5's. I dunno if they would still fit under with the 15x8 wheels. I just know I was very disappointed when I bought those Impala wheels and they didn't work out.
