Engine/Drivetrain
Rubber Gas Line
Topic: Rubber Gas Line (Read 2903 times)
rainman15
Steve
Rubber Gas Line
January 30, 2011, 12:52:39 pm »
Are there different grades of rubber gas line? For instance would the gas line on the suction side of the fuel pump be of a stiffer build quality to prevent it from collapsing? And on the pressure side between the pump and carb would be a different grade of fuel line to handle the pressure?
84 GMC High Sierra 4x4 shortbed
09 GMC Sierra SLT
09 Mercedes Benz C-350
60 Chevrolet Impala
beastie_3
Josh
Re: Rubber Gas Line
January 30, 2011, 01:08:08 pm »
Yes and no. Yes there are different fuel lines- regular, Fi, and diesel. No, the fuel line wont collapse from the fuel pump. BUT you want to run the line as much as possible with a steel bent line.
Semper Fi
Engine/Drivetrain
Rubber Gas Line
