Author Topic: Stabilitrak  (Read 5272 times)
Offline Da67goatman
  • Burban
Stabilitrak
« on: February 05, 2011, 06:56:37 pm »
Does anyone have feedback on GM's stabilitrac system?  My dad is curious about how it works, what it does and if its worth it's worth the extra money?  Thanks guys.
<Pitcrew>
Re: Stabilitrak
« Reply #1 on: February 05, 2011, 07:15:38 pm »
ABS Description and Operation (With JL4)
This vehicle is equipped with a TRW EBC445 brake system. The electronic brake control module (EBCM) and the brake pressure modulator valve assembly are serviced separately. The brake pressure modulator valve assembly uses a 4 circuit configuration to control hydraulic pressure to each wheel independently.
The vehicle is equipped with the following braking systems:
Antilock Brake System (ABS)
Engine Drag Control (EDC)
Dynamic Rear Proportioning (DRP)
Traction Control System (TCS)
Vehicle Electronic Stability (VES)
The following components are involved in the operation of the above systems:
Electronic brake control module (EBCM)-The EBCM controls the system functions and detects failures. The EBCM contains the following components:
System relay-The system relay is energized when the ignition is ON and no ABS DTCs are present. It supplies battery positive voltage to the solenoid valves and pump motor.
Vent tube-The vent tube, located in the EBCM connector, is an opening to the internal cavity of the EBCM. It allows ventilation of the EBCM internals.
Brake pressure modulator valve (BPMV)-The BPMV contains the hydraulic valves and pump motor that are controlled electrically by the EBCM. The BPMV uses a 4 circuit configuration with a diagonal split. The BPMV directs fluid from the reservoir of the master cylinder to the left front and right rear wheels and fluid from the other reservoir to the right front and left rear wheels. The diagonal circuits are hydraulically isolated so that a leak or malfunction in one circuit will allow continued braking ability on the other. Important: There is a rubber isolator located under the BPMV and on the mounting studs. The rubber isolators protect the BPMV and the EBCM from vehicle vibrations.
The brake pressure modulator valve contains the following components:
Pump motor
Inlet valves (one per wheel)
Outlet valves (one per wheel)
Master cylinder isolation valves (one per drive wheel)
Prime valves (one per drive wheel)
Wheel speed sensors (WSS)-EBCM sends a 12-volt reference voltage signal to each wheel speed sensor. As the wheel spins, the wheel speed sensor produces a square wave DC signal voltage. The wheel speed sensor increase the signal frequency as the wheel speed increases, but does not increase the signal amplitude.
Traction control switch-The traction control system is manually disabled or enabled using the traction control switch.
The EBCM uses the brake apply sensors as an indication that the brake pedal is applied.
Lateral accelerometer sensor-The EBCM uses the lateral accelerometer sensor as an indication of the lateral acceleration of the vehicle.
Yaw rate sensor-The EBCM uses the yaw rate sensor as an indication of the yaw rate of the vehicle.
Steering wheel position sensor (SWPS)-The EBCM uses the SWPS as an indication of the position and rotation of the steering wheel.
Initialization Sequence
The EBCM performs 1 initialization test each ignition cycle. The initialization of the EBCM occurs when 1 set of the following conditions occur:
Both of the following conditions occur:
The EBCM detects that there is a minimum of 500 RPM from the ECM via a serial data message.
The brake apply sensor switch is not applied.
OR
The vehicle speed is greater than 16 km/h (10 mph).
The brake apply sensor switch is applied.
The initialization sequence may also be commanded with a scan tool.
The initialization sequence cycles each solenoid valve and the pump motor, as well as the necessary relays, for approximately 1.5 seconds to check component operation. The EBCM sets a DTC if any error is detected. The initialization sequence may be heard and felt while it is taking place, and is considered part of normal system operation.
The EBCM defines a drive cycle as the completion of the initialization sequence.
When wheel slip is detected during a brake application, the ABS enters antilock mode. During antilock braking, hydraulic pressure in the individual wheel circuits is controlled to prevent any wheel from slipping. A separate hydraulic line and specific solenoid valves are provided for each wheel. The ABS can decrease, hold, or increase hydraulic pressure to each wheel brake. The ABS cannot, however, increase hydraulic pressure above the amount which is transmitted by the master cylinder during braking.
During antilock braking, a series of rapid pulsations is felt in the brake pedal. These pulsations are caused by the rapid changes in position of the individual solenoid valves as the EBCM responds to wheel speed sensor inputs and attempts to prevent wheel slip. These pedal pulsations are present only during antilock braking and stop when normal braking is resumed or when the vehicle comes to a stop. A ticking or popping noise may also be heard as the solenoid valves cycle rapidly. During antilock braking on dry pavement, intermittent chirping noises may be heard as the tires approach slipping. These noises and pedal pulsations are considered normal during antilock operation.
Vehicles equipped with ABS may be stopped by applying normal force to the brake pedal. Brake pedal operation during normal braking is no different than that of previous non-ABS systems. Maintaining a constant force on the brake pedal provides the shortest stopping distance while maintaining vehicle stability.
Pressure Hold
The EBCM closes the inlet valve and keeps the outlet valve closed in order to isolate the system when wheel slip occurs. This holds the pressure steady on the brake so that the hydraulic pressure does not increase or decrease.
Pressure Decrease
The EBCM decreases the pressure to individual wheels during a deceleration when wheel slip occurs. The inlet valve is closed and the outlet valve is opened. The excess fluid is stored in the accumulator until the return pump can return the fluid to the master cylinder.
Pressure Increase
The EBCM increases the pressure to individual wheels during a deceleration in order to reduce the speed of the wheel. The inlet valve is opened and the outlet valve is closed. The increased pressure is delivered from the master cylinder.
The dynamic rear proportioning (DRP) is a control system that replaces the hydraulic proportioning function of the mechanical proportioning valve in the base brake system. The DRP control system is part of the operation software in the EBCM. The DRP uses active control with existing ABS in order to regulate the vehicle's rear brake pressure.
The red brake warning indicator is illuminated when the dynamic rear proportioning function is disabled.
When the driver releases the throttle, and the drag from the engine overcomes the frictional force between the tire and the road, EDC becomes active.
The EBCM sends a torque request signal to the ECM, which increases the torque at the wheels. This stabilizes the wheels by reducing the slip at the driven wheels.
When EDC is active, the driven wheels are controlled to a target below the non-driven wheels.
When drive wheel slip is noted while the brake is not applied, the electronic brake control module (EBCM) will enter traction control mode.
First, the EBCM requests the engine control module (ECM) to reduce the amount of torque to the drive wheels via the serial data. The ECM reduces torque to the drive wheels by retarding spark timing and turning off fuel injectors. The ECM reports the amount torque delivered to the drive wheels via the serial data circuit.
If the engine torque reduction does not eliminate drive wheel slip, the EBCM will actively apply the drive wheel brakes. During traction control braking, hydraulic pressure in each drive wheel circuit is controlled to prevent the drive wheels from slipping. The master cylinder isolation valve closes in order to isolate the master cylinder from the rest of the hydraulic system. The prime valve then opens in order to allow the pump to accumulate brake fluid in order to build hydraulic pressure for braking. The drive wheel inlet and outlet solenoid valves then open and close in order to perform the following functions:
Pressure hold
Pressure increase
Pressure decrease
ABS Indicator
The instrument panel cluster (IPC) illuminates the Antilock Brake System (ABS) indicator when the following occurs:
The electronic brake control module (EBCM) detects a malfunction with the antilock brake system. The IPC receives a serial data message from the EBCM requesting illumination.
The IPC performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 5 seconds.
The IPC detects a loss of serial data communications with the EBCM.
Traction Control System Indicator
TRAC OFF
The instrument panel cluster (IPC) illuminates the TRAC OFF indicator when the following occurs:
The electronic brake control module (EBCM) inhibits the traction control system due to a malfunction in the traction control system. The IPC receives a serial data message from the EBCM requesting illumination.
The body control module (BCM) detects that the traction control switch has been pressed (signal circuit is low). The BCM sends a serial data message to the EBCM in order to disable traction control. The IPC receives a serial data message from the EBCM requesting illumination. The BCM sends a serial data message to the radio in order to activate an audible warning.
The vehicle electronic stability enhancement system (VES) adds an additional level of vehicle control to the EBCM.
Yaw rate is the rate of rotation about the vehicle's vertical axis. The VES is activated when the EBCM determines that the desired yaw rate does not match the actual yaw rate as measured by the yaw rate sensor.
The desired yaw rate is calculated from the following parameters:
The position of the steering wheel
The speed of the vehicle
The lateral, or sideways acceleration of the vehicle
The difference between the desired yaw rate and the actual yaw rate is the yaw rate error, which is a measurement of oversteer or understeer. If the yaw rate error becomes too large, the EBCM attempts to correct the vehicle's yaw motion by applying differential braking to the appropriate wheel. The amount of differential braking applied to the left or right front wheel is based on both the yaw rate error and side slip rate error.
The VES activations generally occur during aggressive driving, in turns or on bumpy roads without much use of the accelerator pedal. When braking during VES activation, the pedal pulsations feel different than the ABS pedal pulsations. The brake pedal pulsates at a higher frequency during VES activation.
Re: Stabilitrak
« Reply #2 on: February 05, 2011, 07:21:29 pm »
Offline Layne
Re: Stabilitrak
« Reply #3 on: February 05, 2011, 09:06:04 pm »
Does that mean you can still do burnouts?
Offline Da67goatman
  • Burban
Re: Stabilitrak
« Reply #4 on: February 05, 2011, 10:01:09 pm »
Does that mean its like ABS on a fully loaded truck, you have to disconnect it to have brakes.  Will I have to override it in order to maintain control?
<Pitcrew>
Offline 76k104x4
Re: Stabilitrak
« Reply #5 on: February 05, 2011, 11:41:32 pm »
my dad has one with it basically when you start spinning the tires it stops it unless you override it with the push button i personally think it sucks having to override it before you hit a little mudhole or try to pull out in front of somebody and you have to get on it a little bit but hey i am 23 years too  8)
Re: Stabilitrak
« Reply #6 on: February 14, 2011, 08:33:07 pm »
It's a good thing as 99% of the people on the road are terrible drivers and panic just jamming on the brakes.
