Author Topic: Will it fit?  (Read 3753 times)
Offline Jireh Customs
  • New Users
Will it fit?
« on: February 08, 2011, 11:10:34 pm »
I am looking at buying a 1973 one ton work truck with a worn out 454 and th400 trans. Will a Pontiac 455 and th400 bolt right in of will it be a headache?
Offline Layne
Re: Will it fit?
« Reply #1 on: February 09, 2011, 12:00:49 am »
Is the th400 BOP style?
  • New Users
Re: Will it fit?
« Reply #2 on: February 09, 2011, 12:10:37 am »
The th400 with the 455 is bop
Offline Layne
Re: Will it fit?
« Reply #3 on: February 09, 2011, 12:12:20 am »
I think the only issue you'd have is the motor mounts, and I'm not sure of the adaptors. I've never done this swap, but I'm sure more experienced guys on here will have some words of wisdom.
Re: Will it fit?
« Reply #4 on: February 09, 2011, 09:50:03 am »
To get it to bolt in you probably need to make mounts if the engine is a pontiac.
An olds can be made to bolt right in if you use 5.7L diesel engine mounts and stands.
