Author Topic: air condition  (Read 75016 times)
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
air condition
« on: May 21, 2006, 08:38:00 pm »
I have a problem.   When I turn on my A/C, either on hi or norm, the fuse blows for the blower/speedo/a/c circuit.  So i did some experimenting: I purchased  about a dozen 20 amp fuses and tried with the a/c wires not even plugged into the compressor....It will still blow...
This plug on the compressor can be removed and the fuse still blows. So I know it is not the compressor.  When I put it on just blower vent or heat, the fuse does not blow.  I put it on A/C and it blows again.  I have tracked the two wires that go to the compressor up to the firewall where it joins many other wires in the covered harness. No signs of breaks in the coating.  So, i started thinking about the a/c relay but do not know where it is located.
This is the relay i bought.  but don't know where to plug it in.
Anyone have any ideas as to why my fuse keeps blowing when i slide the controls to AC?  And where is the relay located.
It is a 91 sub  w/ rear a/c.  The rear a/c blower is on a different circuit because it still works when the fuse for the a/c blows.
SgtDel
Edited by: SgtDel at: 5/21/06 7:42 pm
Offline cooltoolguy
Re: air condition
« Reply #1 on: May 21, 2006, 09:04:00 pm »
Del,  the light green and dark green wires going to the pressure switch on the desicant container, have you tried disconnecting them? dont remember if the ac will turn on or not if it is disconnected, but that switch may be shorting out to ground.  i believe dark green wire is a/c request which hooks to the pcm (tbi, right?) to bump up the idle, light green should be to the switch in dash.  just a thought, I'll grab my book out of the garage tomorrow for the diagrams.
BTW your truck my not have a relay,  my 86 does not have one since (not so sure about the 94)the votage to engage the clutch is minimal,  there is only one large power wire which goes the the silver box on the blower case, and then it splits from there to the fan motor etc.
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
> Re: air condition
« Reply #2 on: May 21, 2006, 09:52:00 pm »
Cooltoolguy, You brought up some good ideas.  If i pull the wires from the pressure switch the clutch will not engage, but that may help me diagnose where a problem is (will see if fuses still blow w/ ac on.  Yeah, my 91 is a tbi.
And come to think about it, the idle DOES NOT increase like i think it should when AC is on.  In fact, it seems as though the rpms of the engine are barely turning the ac compressor, i kind of get a roaring sound from the compressor when engine is idling and ac is on. That is when the ac was working, up until last week.
I am going to try tomorrow to unplug the blower resistor and see if i can further limit some possibilities.  The blower does work well w/ the heater and vent, just breaks fuses when ac is on.
I'll also unplug the pressure switch and then switch to ac and see if she breaks a fuse then.
That would make sense if I don't have an ac relay.  I know the blower has a relay for high on top the evaporator box.  I think those are the other wires that plug to that gizmo on top the box.
SgtDel
Re: > Re: air condition
« Reply #3 on: May 21, 2006, 10:24:00 pm »
« Reply #4 on: May 21, 2006, 10:26:00 pm »
Del, I think you got the blower relay. It sounds to me like the AC switch itself would be a good place to look. From there the problem lies from the switch to the load in the ckt. So pop the switch out ...
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #5 on: May 22, 2006, 09:34:00 am »
vilezombonie, thanks for the schematics.  That'll tell me where the wires go and what they are for.  I hope it is something simple such as a pressure ac switch.  I can replace that easily.  gonna try that this afternoon.  There has been no work on wires and such since  before the thing started acting up.  I cannot believe a wire is shorting unless those dang squirrels started chewing on my truck wires again, like they did on my 79.  I set up a trap and hauled 20 sqirrels away.
Note: the schematics say htr/ac 25 amps in the top left corner.  My fuse for the speedo/blower/a.c. is a yellow 20 amp fuse.  hmmmmm.
I'll keep everyone posted.
SgtDel
Edited by: SgtDel at: 5/22/06 8:51 am
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: air condition
« Reply #6 on: May 22, 2006, 05:15:00 pm »
OK, I've narrowed the problem down just a little.  The fuse blows each time I turn the AC on when the cycle pressure switch is attached.  When I unplug the cycle switch, the fuse doesn't blow.  Even when I jump the switch (bypass it altogether) the fuse blows.  So, the problem is somewhere on the dark green wire, either going to the compressor or the ECM.  Unfortunately, the dark green wire branches to both places according to the schematic above. The big problem is the wire is covered completely under the black tape stuff.  I guess I will just have to start tearing away the black harness tape to try and find the problem, perhaps a short somewhere.
SgtDel
Re: Re: air condition
« Reply #7 on: May 22, 2006, 06:29:00 pm »
pull the diode out of the connector @ the compressor.
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: air condition
« Reply #8 on: May 22, 2006, 08:30:00 pm »
I noticed that little diode b/w the green hot wire and black ground.  What in the world is that for?  It seems that it would short it out.
But, that wasn't the problem, it was a little nick in the dk green wire way back by the distributor.
After blowing all these fuses..
I finally figured it out. Thanks to each of you for helping me figure it out.
SgtDel
91 blu burb
Edited by: SgtDel at: 5/22/06 7:31 pm
Offline cooltoolguy
Re: air condition
« Reply #9 on: May 22, 2006, 07:59:00 pm »
hooray:D
