Author Topic: rebuild parts question  (Read 3388 times)
Offline thachevythang
« on: February 11, 2011, 03:26:03 am »
Rebuilding a 305 to replace a strait 6. Needing some help on some parts if anybody doesn't mind.
Purchasing this kit: http://www.summitracing.com/parts/FEM-CSMHP749-000/
With this cam: http://www.summitracing.com/parts/CCA-12-600-4/
Getting proper lifters as well. Whats the best timing gear set I can get from summit with this application?
Do I need to also purchase the oil pump driveshaft and gear? Or can it be reused?
Thanks in advance!!!
'85 SHORTBED
Offline acefoxx
  • 84 SierraClassic stepside/85 K5 Blazer
    • Acefoxx.com
Re: rebuild parts question
« Reply #1 on: February 11, 2011, 09:48:21 am »
The oil pump drive shaft can be reused but check the condition of the plastic sleeve on the one end of it. Your putting in a new oil pump I assume. If the engine is apart anyhow I would highly recommend it. You shouldn't have to buy a gear because the gear is part of the distributor. Any double roller timing chain will work fine. I wouldn't go with a timing gear unless you like the noise.
'84 GMC SierraClassic/'85 K5 Blazer Silverado
http://acefoxx.com
