Body, Glass & Paint
Adjusting Door Question
Topic: Adjusting Door Question (Read 5534 times)
Kris_77stepside
February 14, 2011, 06:36:14 pm »
So I'm probably going to sound like an idiot cause I went to auto body school but I can't seem to figure out how to slide the door back as in close the gab between the rear of the cab and back edge of the door. I took the fender off and loosened the 3 bolts on the bottom hinge where it connects to the cab, then the 2 on the top hinge. But there is also another one on the top hinge where instead of a bolt head, there is a nut welded to the hinge and looks like a bolt going from the inside of the cab to the nut, but when I looked under the dash and everything there was no bolt head anywhere that would allow you to loosen it. If anyone can help that would be awesome.
frogman68
Re: Adjusting Door Question
February 14, 2011, 06:50:52 pm »
That top one is a bear
Look up by the parking brake pedal you will see a hole the bolt is in there
Kris_77stepside
February 14, 2011, 07:00:28 pm »
Well I was working on the passenger side but do they have like caps or something over them cause the glove box is out and I was looking and feeling in there but there was no bolt heads. I found a round spot kinda by the dash where it looks like it is but it was smooth. I'll have to look better tomorrow.
February 14, 2011, 08:20:19 pm »
remove the grommet for the door jam switch wiring and it's a straight shot to the bolt.
HAULIN IT
February 14, 2011, 08:38:15 pm »
Tape the socket on the extension if you don't have the kind that lock on
Kris_77stepside
February 23, 2011, 10:25:00 am »
Just thought I would let everyone know I figured it out. Turns out that flat part where the bolt when to was a plug/cap thing that was covering up the head. Got the door adjusted so it shuts like new.
February 23, 2011, 05:26:28 pm »
That plug thing is the grommet I mentioned above. Glad you got it adjusted. Make sure your hinge bushings are good and striker bushing is in tact.
thirsty
February 23, 2011, 07:28:49 pm »
Quote from: HAULIN IT on February 14, 2011, 08:38:15 pm
Good advise. I dropped the bolt down there once, took a while to get it out.
Build thread
February 23, 2011, 08:15:17 pm »
Get some cheap magnetic extensions
Body, Glass & Paint
