Author Topic: 76 radio  (Read 14969 times)
maverick
  • Guest
76 radio
« on: September 30, 2001, 03:22:00 pm »
how does the wiring work?
my am originally had one speaker in the dash.
I want to go to a stereo with dual speakers.
The am/fm radio I got only has one witre to the speakers!!
maverick
camel
  • Guest
maybe a new radio?
« Reply #1 on: September 30, 2001, 03:52:00 pm »
if your am radio only puts out one channel, then you can only run one channel. because i doubt that you can bridge that little am to 2 ohms. and run the speakers in parallel. if you bought a cd player, or a tape player then you could have 4 channels, and run more speakers.
Offline G7M6C
Re: maybe a new radio?
« Reply #2 on: October 09, 2001, 10:24:00 pm »
if you do put a new radio in you are going to have to splice into a constant power supply.  the old wires do not have  a constant supply.  if i can remember right you have an ignition on hot wire, a ground wire, and the positive and negative speaker wires.
