Author Topic: Changing from manual to power brakes  (Read 5732 times)
Offline burbboysgc
« on: February 26, 2011, 12:15:16 am »
What would have to be done to change my manual brakes to power? Could I put the master cylinder on a brake booster and put it back on the original spot on the fire wall, or is there more to it than that? I know I'll have to hook up a vacuum source from the manifold to the booster, but what about the mechanism behind the fire wall, pedal assembly etc?
1987 C20 3/4 suburban 454 tbi th 400/2wd - 1985 C10 short bed 305/350 turbo 2wd
1979 swb Custom Deluxe 2wd roller
Offline team39763
Re: Changing from manual to power brakes
« Reply #1 on: February 26, 2011, 11:14:53 am »
I went the other way(power to manual).  I changed the master/booster assembly, and also the pedal and the big steel pedal/steering support(above the pedal).  That was all.
Offline bowtieman82
« Reply #2 on: March 08, 2011, 01:27:54 pm »
the easyest way to do it is to go to a junk yard and take one off a another truck. the peddle the boaster and the master cylinder.  and look at what they have and see if they look like yours,  if not buy it.
