Author Topic: power steering only works when car is moving.  (Read 4762 times)
Offline txchainsawgogi
« on: March 18, 2011, 09:06:15 pm »
otherwise it wont budge. well, it does a little but really feels like its out completely. no huge leaks and all the hoses are there haha. i noticed though that on the steering column, where it meets the power steering gear(?) theres a lot of wetness.
i hope its just the power steering pump's bearings going out because thats a much cheaper part to replace.
Re: power steering only works when car is moving.
« Reply #1 on: March 18, 2011, 09:59:55 pm »
Try draining the fluid, and replacing it. I had a pump on and 81 Jimmy once that did this. I sucked the fluid out, filled it with mystery oil drove it around town for about 20 mins, sucked it out and refilled with fresh ATF. It work perfect after that.
« Reply #2 on: March 19, 2011, 07:12:42 pm »
can anyone tell me what I need to do to fix the part in the picture? Are there just worn gaskets or orings making it leaky/wet right there?
« Reply #3 on: March 19, 2011, 07:22:58 pm »
just a bad seal, but the word on rebuilding them is that it is a pain in the but. I suppose if you had a back up box, there is no reason not to attempt it if your willing to spend a few more bucks for the rebuild kit. they did it on powerblock tv and it didnt look too hard. but that is TV.
« Reply #4 on: March 19, 2011, 07:46:50 pm »
haha well i've never rebuilt one. i guess i'd rather do that than spend 200 on it. think there are any how tos on here? im not even 100% sure what that part is called.
