Author Topic: body mounts ????  (Read 5359 times)
Offline spectreblazer
body mounts ????
« on: March 21, 2011, 10:58:08 pm »
why are body mounts listed in different years if the frames are the same 73-87??
enlighten me some please
i have an 84 but wondering if this kit would work http://www.autopartswarehouse.com/details/QQChevroletQQK20QQEnergy_SuspQQBody_Mount_KitQQ19751980QQE1234103G.html?apwcid=P1135867996W43b3f85c7ab9e&apwid59DkUOj
any other recommendations?
Re: body mounts ????
« Reply #1 on: March 21, 2011, 11:31:50 pm »
forget what years but one set of years have oval holes while the other have round
Offline 80stepsideguy
« Reply #2 on: March 22, 2011, 03:39:00 am »
1973-1980 frames are all the same,81-7 are all the same as well.They changed the mounts in 81.If your truck has a 73-80 frame then you need to use the specified years.If its a 81-7 it goes the same for them years as well.But if you got a 81 n up truck with a 73-80 frame under it you need to use the 73-80 mounts, vice a versa for the 81 n up frame as well..
thanks
Pat
1998 Chevy 1500 S/B 2wd
« Reply #3 on: March 22, 2011, 08:18:25 am »
That kit is for 73-80. It wont work on an 84 frame.
