Author Topic: heater/blower motor  (Read 4578 times)
Offline bigfosty
heater/blower motor
« on: March 31, 2011, 06:42:31 am »
Okay guys, did a search and got a few ideas on what might be wrong, but I'm willing to listen to all ideas. When I first got my truck the heater would only blow on three quarter speed, then all of a sudden it quit. I put power to the motor directly from  the battery and it turns on so the motor is good, I replaced the relay, I checked the fuses but don't know which one is for the blower they all looked good but if you can tell me which one is for the heater I will check again, I pulled the resistor and it looked fine but I havene't tried a new one yet, and I put a different switch in (the actual switch on the dash you change the fan speed with) but it was out of a junkyard truck so it could be that. Anything alse I need to check? Anybody run into this before? Thanks for any help, I really miss driving my truck, it's just too dang cold without a heater.
P.S.- It's a 75 K-10
Re: heater/blower motor
« Reply #1 on: March 31, 2011, 08:42:23 am »
     I'm not sure about your case, but my switch was causing my problem, it would only blow on high and nothing else until I changed switches.  Hope this helps.
« Reply #2 on: March 31, 2011, 01:01:56 pm »
sounds like the switch to me.
Offline 1980c10
« Reply #3 on: March 31, 2011, 06:48:30 pm »
had been a switch on mine also, I replaced the entire control though
Offline RonS
« Reply #4 on: April 06, 2011, 10:19:33 am »
I bet it is the resistor.
