Author Topic: Radiator Mounts  (Read 4701 times)
Offline Da67goatman
  • Burban
Radiator Mounts
« on: April 20, 2011, 09:03:15 am »
How is the radiator supposed to be mounted?  Mine is sitting on wood blocks, and I know that is wrong.  Are there special rubber mounts that I can buy?  Thanks.
<Pitcrew>
Offline Grim 82
Re: Radiator Mounts
« Reply #1 on: April 20, 2011, 09:12:25 am »
Yes, there are 2 rubber mounts that go on the radiator support that it sets in.
Offline bigchevyc30
  • the pig
Re: Radiator Mounts
« Reply #2 on: April 20, 2011, 09:34:17 am »
its actually 4 2 for the top 2 for the bottom my truckwas missing them and when i got the new motor i asked the guy if i could get the rupper pieces of the truck hes selling for parts
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
Offline Da67goatman
  • Burban
Re: Radiator Mounts
« Reply #3 on: April 20, 2011, 10:49:28 am »
Anyone know who sells these?  I called around and no one seems to be able to get them.  Even the dealer can't get them anymore.
<Pitcrew>
Offline bigchevyc30
  • the pig
Re: Radiator Mounts
« Reply #4 on: April 20, 2011, 11:06:37 am »
you would have to go to a junk yard or pullapart to get them and you would have to hope they are there cause i couldnt get anything for it. i was lucky to get the ones for my truck off the truck i got the motor from. hope you can find them
Re: Radiator Mounts
« Reply #5 on: April 20, 2011, 02:49:37 pm »
Capt might be able to get them.
Offline Psycho71
Re: Radiator Mounts
« Reply #6 on: April 21, 2011, 08:38:20 am »
If not available on this site, then some of the more major parts vendors out there will have them. No mentioning any names quite yet. But they are not that hard to find if you really start looking. There are also the saddles they sit in on the bottom. If the rad. is sitting on wooden blocks, you might make sure the saddles that hold the rubbers are still there. Now those, I've never seen sold through a vendor. Most likely a junkyard trip is in order.
Re: Radiator Mounts
« Reply #7 on: April 21, 2011, 09:47:58 am »
I am looking but the lower ones I haven't found yet.
