Author Topic: Big Block 427 Update w/pics  (Read 33018 times)
Offline big bear
Re: Big Block 427 Update w/pics
« Reply #30 on: May 21, 2011, 11:43:36 am »
soooo...the suspense is building man.haha. you get her running ?
Offline TxFiddler
« Reply #31 on: May 21, 2011, 12:52:11 pm »
Just a trial fire up the other day.  No issues at all.  Gonna try to get time this weekend and run the wires and radiator and all and start it up and let it idle.  It is soooooo loud with open headers.  It sounds super strong.  The Holley Street Avenger worked right out of the box as advertised.  The cam sounds great.  Maybe I can post a vid or at least an audio clip after Sunday... ;D
80 C10 2wd / 427 BigBlock / 700R4 / 3:42 Eaton Posi LSD / 770 cfm Holley Street Avenger / Doug's Headers / MSD ProBillet Distributor / Champion 3 row Radiator
Offline big bear
« Reply #32 on: May 21, 2011, 08:31:44 pm »
awesome!!!!  hey that will tide me over for now.  haha
Offline slammed79
  • Thou shalt not drive stock
« Reply #33 on: May 28, 2011, 10:44:59 pm »
So Fidd, whats happenin here? I wanna see some smokey big block burnouts ;D
Praise the lowered
Offline big bear
« Reply #34 on: May 29, 2011, 07:12:19 am »
that makes two of us  !!
Offline HAULIN IT
« Reply #35 on: May 29, 2011, 08:57:30 pm »
No wiring needed other than a 12 volt keyed.  The trans has a ground strap.  The way that Phoenix does the lockup, when ever it's in 4th gear, it automatically locks.  When it downshifts, it unlocks.  Pretty cool.
Are you saying that the converter will lockup as soon as it goes into 4th...as in, any time it's in 4th the lock up in the converter is locked? Or just that the clutch won't lock up in 2nd or 3rd...just 4th? Lorne
Offline TxFiddler
« Reply #36 on: May 29, 2011, 09:50:03 pm »
Won't lock up in anything but 4th.  I'll let in ya know more in a few days when it's on the road.
Offline TxFiddler
« Reply #37 on: May 29, 2011, 10:08:50 pm »
Worked on the engine compartment today.  Wires all cleaned up.  Tranny lines measured and ran, just need to install the cooler.  Put on a GM Performance air breather.  Got the other fender on and just gotta get everything lined up and bolted up tight and get the fans wired in.  Whew....what a bunch of bolts.  Man things sure slow down during this phase.  Hopefully on the road Wednesday (my next day off).  Hope everyone has a great and safe Memorial Day and remember the reason for the day.  Here's a few recent pics.
More to follow soon.
Took these next two with the lights off and flash on.  Looks kinda cool.  Brings out the black.
This one's my fav so far.
Offline big bear
« Reply #38 on: May 30, 2011, 10:15:20 am »
wow..looks sweet man.   very envious.  good luck wrapping up the smaller things.  have a great memorial day as well.  and  cant wait for wednesday to get here now ! lol
Offline bigchevyc30
  • the pig
« Reply #39 on: May 31, 2011, 02:02:10 pm »
man u got me jealous i want one for my truck :'(
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
Offline Grim 82
« Reply #40 on: May 31, 2011, 04:01:56 pm »
That looks great.
Just a friendly reminder though...  If you are running a flat tappet cam you will want to avoid letting it idle and do the proper cam break-in procedure. If this is the case you will not want to use those new headers right away because it could ruin the coating. If you're using a roller cam disregard this post. Nice work
Offline TxFiddler
« Reply #41 on: May 31, 2011, 09:10:06 pm »
That looks great.
No Worries Grim.  Running a roller cam.  Nice and smooooth.  Thanks for the heads up though.
Fidd
