Author Topic: Starter Troubles  (Read 5698 times)
Offline mach1mustang351
Starter Troubles
« on: May 09, 2011, 01:14:32 am »
If anyone can help me with this I will be forever grateful.  I have recently put a 350 TPI out of an '88 IROC in my 1973 K2500 GMC.  I also have a 4 wheel drive 700R4 out of an '89 pickup and the stock NP205.  I got everything adapted wired in and all that I went to crank it over and the solenoid engaged the motor spun and that was it.  No engagement at all with the flywheel.  I find it hard to believe this is a shim issue when there was no engagement at all.
I used the flexplate off the '88 IROC and a starter that matches the application for the trans.  it is a diagonal mounted.  If there is anything I am missing here let me know.  I would love to hear this thing run.
Thanks
Offline 1979C20
  • Kyle Taulton.
Re: Starter Troubles
« Reply #1 on: May 09, 2011, 02:21:01 am »
You need the starter that matches the flex plate. Your flex plate is probably smaller in diameter hence the starter gear not engaging with it.
Offline Cheyenne
« Reply #2 on: May 09, 2011, 02:46:18 am »
He's right I had a similar issue with a 77 ford f150 once I matched everything up engaged and started..
« Reply #3 on: May 09, 2011, 11:43:31 am »
Well I used my skills as a parts guy and the Camaro takes a 153 tooth flywheel and the truck would have had a 168.  I'm going to do some more research to see If I can find a unit that will work but still allow me to put my inspection cover on.  I can install the Camaro starter but no cover.  Why are there issues when you install no-matching parts... weird ;)
Offline 1979C20
  • Kyle Taulton.
« Reply #4 on: May 09, 2011, 12:17:31 pm »
Modify your inspection cover to use the Camaro starter? Or, if you're up to it, pull the engine or the tranny and put a truck flex plate to match the starter on it. Then you can use your inspection plate.
« Reply #5 on: May 09, 2011, 01:02:27 pm »
yea, that's what i think I have settled on.  Thanks for the help.
Offline 1979C20
  • Kyle Taulton.
« Reply #6 on: May 09, 2011, 01:16:44 pm »
No problem, let us know if you get it working!
