Author Topic: Wiring an amp  (Read 8490 times)
Offline Copper Canyon
Wiring an amp
« on: February 01, 2007, 02:45:00 pm »
I'm not too good at the whole wiring thing...wanted to know if any of you knew if it is possible to run 4 speakers plus a sub off of a 2 channel amp.  I figure there is someway to split the signal, but I don't know how.:rolleyes
Re: Wiring an amp
« Reply #1 on: February 01, 2007, 05:32:00 pm »
Not without blowing up the amp! Why don't you either run a high output stereo 4 channel and use your 2 channel bridged to your sub or just get one 4 channel amp?
2 Channel Amp
« Reply #2 on: February 01, 2007, 06:42:00 pm »
I wasn't going to actually try it.  I didn't think it would be possible, but I just wanted to hear it from someone who knows more about this stuff than I do.  Thanks for the reply.
Offline pcmcobra
yes u can
« Reply #3 on: February 03, 2007, 09:37:00 pm »
u can run an entire system off a 2 channel amp. It's not easy, and you have to have a very good 2 channel amp...
Like orion....1/2ohm stable..
Offline speedy
Re: Wiring an amp
« Reply #4 on: October 10, 2007, 03:21:09 pm »
You could actually wire the main speakers in 8 ohm series and then, depending on the amp, bridge the sub.  It's called a 2+1.
Offline okuma
Re: Wiring an amp
« Reply #5 on: October 10, 2007, 08:48:16 pm »
YES ! IT CAN BE DONE ! I had an old punch amp running fronts, rears , and a 10" subwoofer! never had a problem..... yes ! by experience.
